Question about LG Vu CU920 Cellular Phone
My phone doesnt charge
I tried charging the phone with the charger inserted all the way but it wont charge . it only charges when the charger is instered at a certain angle and sometimes it doesnt charge at all . what should i do ?
If it only charges at a certain angle, that means that one of the tracks and/or pieces of metal is not alligned correctly. The only thing that you can do is report it under warranty/insurance and try to get a new one.
Posted on Feb 23, 2009
Samsung galaxy Y pink wont charge
i tHink iNnn yOur cEll pHone cHarging piNn iZzz dEstroyed !!....!! rEpair yOur cEll pHone tHen iTz wOrking !!....!!
Apr 07, 2013 | Samsung Galaxy Y Gt-s5360 Pink Factory...
My motorola citrus doesnt charge all the way
It because if you looked where you charged your phone it might be dent you might off but your charger and click moving i know that because in my droid razer i did the same and know it wont charged that's why i using my motolora phone
Jan 02, 2013 | Motorola Mobility CITRUS Smartphone
My jet s8000 not charging
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Hope this help in solving the problem....
Nov 16, 2010 | Samsung Jet S8000 Cell Phone
My phone will not charge? when i put the charger in sometimes the red lght comes on and sometimes it doesnt. Either way it will not charge at all.
hi friend,
this problem happens to more phones when another sutable charger is tried to insert in the charging slot of ur mobile phone......
get it to a costomer care and change the charging slot
Jul 12, 2010 | Sony Ericsson K610i Cellular Phone
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Oct 10, 2008 | LG Shine KE970 Cellular Phone
Lg mobile battery indicator
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Feb 03, 2008 | LG KG220 Cellular Phone
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
LG Vu CU920 Cellular Phone Logo
164 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
