Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Shadows (Red, Blue) on the pictures
It seems that you are watching a 3D pictures and there is a curve red lines on the left corner
  • Edward
    Edward Feb 28, 2009
  • Edward
    Edward May 11, 2010
    Your TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
    Scholar:
  • 41 Answers
I agree with Ecullier2012. This is a convergence issue. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That site pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present in some areas and they can reside even when the set is unplugged.
Posted on Mar 13, 2009
  • Sony Master
  • 3,459 Answers
Be carefull with adjusting the knobs in the back of the TV. If your TV has a convergence problem - 3D or warped looking - adjusting the knobs will mess everything up and make it worse.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Had the same problem , fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Posted on Mar 12, 2009
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 04, 2009 | Samsung HCN4727W 47" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Red lines taking over my T,V
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
