Question about Whirlpool LER4634J Electric Dryer
Dryer won't start - Whirlpool LER7646EQo
Dryer will not start - timer works and door sensor/switch works. I ordered a new start switch/push button (3398095) but it sounds as if I ordered the wrong part...I should have probably order new Thermal Sensors?
  • Connie Erklin Mar 10, 2009
    I have the same problem. Same dryer. Thought it might be the push to start button parts but after calling around for the part, one person told me it's rare for that part to go bad. She said if I hear the clicking of the timer, it's probably the thermofuse. Any Ideas?
    Genius:
  • 1,122 Answers
IF THE DRYER DOES NOTHING AT ALL I WOULD SAY YOUR MAIN FUSE HAS BLOWN,IT IS ON THE BLOWER BOX AND IS WHITE,YOU CAN REMOVE THE BACK PANEL AND CHECK IT WITH AN OHMS METER,IF YOU GET NO READING IT IS BAD,LET ME KNOW-MIKE
Posted on Feb 23, 2009
Update: I put in a Thermal Fuse Part # 3392519 and we are spinning again! The part will cost about $14.00.
Posted on Mar 10, 2009
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Won't run. Can hear clicks when changing settings, but won't run when push start button.
Check the door switch for continuity.
Remove the rear panel and check the thermal fuse attached to the exhaust vent on the lower left side. It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
If it is blown you must correct the air flow problem also.
Apr 29, 2009 | Whirlpool LER7646E Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer starts on it's own when timer is turned or door is shut
its the door switch more than likely are less likely the push start button stuck
Mar 16, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
743 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
