Question about Microsoft Windows XP Professional
MS XP problem on boot
I just did a fresh install of XP, and when I start up the laptop. Once it is loading all of the startup programs and whatnot, and I click on a program it doesnt open it. Mind you, the hard drive goes wild with trying, but nothing. Also, this only happens when I have the ethernet plugged it, when I start up the laptop without the ethernet cord plugged in, programs start up without a problem.
  • 2 more comments
  • Casey
    Casey Feb 23, 2009
    it does it at home, my dads, and my moms places. all programs freeze. Task manager, firefox, cmd are the ones that i have used and froze, nothing els had i tested.
  • Casey
    Casey Feb 23, 2009
    However reluctant I am to do a full reinstall....again....I will. Luckily all that I wanted on the hard drive has already been lost! I will try just installing the ethernet driver, then doing win update...then try doing all the other things, videocard, sound card, so on.
  • Casey
    Casey Feb 23, 2009
    Thanks, but it didnt work.
  • My reply is May 11, 2010
    Is it one particular program or all?
    Also, did you reinstall your router since from your description, the problem only occurs when you connect the ethernet cable.
    Scholar:
  • 135 Answers
Try another full reinstall, be sure to reinstall your router and download all the updates and service packs from microsoft.
Please send feedback if this does or does not work and we can take it from there.
Posted on Feb 23, 2009
  • My reply is Feb 23, 2009
    Good luck and keep me posted on your progress.
    Best wishes,
    Mike.
    Sorry to hear you're still having problems.
    I can only think that the hard drive has worked loose or has given up altogether.
    If your laptop is still under warranty, then I suggest you return it as faulty.
    If the warranty has expired, you might try a full format of the hard drive before attempting a full reinstall (again ..... I know, don't say it. I know how fed up you must be feeling).
    Last of all. Ditch the drive and fit a new one. If you shop around they are not too expensive.
    Not an ideal solution I know but it may be your final option.
    Before you ditch it though. Remove the drive by unscrewing the cover on the back of the laptop to ensure it is seated properly.
    Good luck and apologies for not being more helpful.
    Regards,
    Mike.
My cf-w7 hang after abt 15 mins
If this just started roll it back by with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
In Win 7 - Start > Start > Search type System Restore.
In XP - Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
There is the option of uninstalling last program(s) that was installed, again in safe mode.
You also try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 13, 2012 | Panasonic Toughbook W7 Notebook
HP COMPAQ 6510b RUNS SOOO SLOW
My recommendation: Install XP.
Well, not that there actually something wrong, but it initially came with XP or Vista. It depends. HP puts it a XP. Check your MS Product key sticker.
It is a simply determination that the laptop just does not have a enough resources to run Win 7 effectively. How do I know, I am using an HP 2.3GHz with XP. I tried Win 7 awhile back and immediately removed it. If fact, I do clean install of XP at least once a year. I do test more software than most.
Here is my Slow Windows Machine! default fix.
  • Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE).
  • Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when you initiate.
Oh yea, in your case disable AREO, and u
se a virus protection with a smaller footprint. Like MS Security Essentials. My PC just couldn't handle McAfee or the likes.
Oct 05, 2012 | HP Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
Hello my Acer aspire one kav10 is stuck on windows xp loading screen. I have already tried to system restore to an earlier point by using safe mode but when the laptop starts up again it gets stuck on the...
One of the drivers or programs that is set to launch during boot is corrupted. You will have to find out which and uninstall / upgrade it.
Boot in Safe Mode, click Start, Click Run and type msconfig and hit enter - the startup management window will launch. Click on the Startup tab and untick all the programs in there. Now reboot. If you get the same error then the problem is with a driver - uninstall them all then download the latest versions from the Acer Support site and install them one by one. If the problem is fixed then one of the programs is corrupted - open msconfig / Startup again and tick one program at a time with reboot until the problem returns: uninstal that program.
Feb 26, 2011 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
We loaded xp home by mistake, and we want to restore to the vista home that came with the gateway gt5408
change boot order to boot from CD F12 key usually on startup and insert CD that came with Pc /laptop
when it boots from CD you get a choice to Update or Install fresh new
go with Fresh New
voila'
Jun 13, 2010 | Gateway GM5084 PC Desktop
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
My laptop is very slow while booting XP. It booting for about 6-8 min. I have a fresh instaled XP and no viruses.
i guess ur using a licensed and 'updated' antivirus..
howevr, hv a glance ovr the software strength..look for startup items (the programs loaded during startup)..download n install n run 'Statup Control Panel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
and microsoft kb890830..remove the unnecessary boot item(s) or do post me a complete list of startup item that the Startup CPL is showing (in itz every tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..
always better to get supervision frm ur system admin/vendor....
Oct 28, 2009 | HP Compaq 6715b Notebook PC
Acer 5102WMLI laptop freeze
boot up and go to start , select run, and type msconfig and hit enter.
this will be a lengthy process, but click on startup tab and uncheck everything. and then reboot and see if this still happens.
If it stops locking up then you just need to start the process of checking each one until you find the program that is causing your problem. you will need to check a box, apply and then reboot. Use google to research items before you check the box and reboot so you can tell what they are and if you need it running at system startup. Antivirus would be a good start to turn back on first!
Good Luck.
Mar 06, 2009 | Acer Aspire 5102WLMi PC Notebook
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
