Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
The Insignia LCD tv shwos no signal?
The Insignia IS-LCDTV32 show "NO SIGNAL" when the set comes on. It has this code below "YPbPr input". The remote will turn the set on, but I can't get it to do anything else.
    Sergeant:
  • 280 Answers
Using the function button or source button on the remote switch to TV mode. that should do it.
Posted on May 01, 2009
Video goes out on insignia lcd
An lcd tv has to have a light source behind it to see the picture. Older ones have flouresent tubes. Newer set have light emiting diodes(led). You need to determine if the backlight is turning off or is set loosing signal. If you press the menu button on the Insignia remote does the menu appear on the screen. If not hold a flashlight on the front of the screen. if you can slightly see some video the the back light is off. If the menu shows then check the signal source. If back light is out the replace the inverter board.
Jan 07, 2014 | Insignia IS-LCDTV32 32 in. Television
It saying .. No Sync what does that mean?
No Sync indicates that the input signal doesn't match the type of signal that the TV can read. A digital source going to an analog input could cause the issue.
What is your source for the signal?
If you are using the DVI connection on the TV to connect to a computer, try using the VGA input instead. Unfortunately not all TVs can interpret the computer's digital signal. (It is different than the digital signal from a set top box.)
The manual for the TV is available from the product site: http://insigniaproducts.com/products/televisions/IS-LCDTV32.html . The direct link to the manual is: http://insigniaproducts.com/cms/documents/IS-LCDTV32%20UM%20EN_SP_FR.pdf .
Please add a comment with your source and I will offer additional suggestions for solving the error.
I hope this helps.
Aug 02, 2011 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 LCD TV with no image and buzzing sound.
Before you throw it in the trash, check the supply voltage to the panel ballast. You should see 24v coming off the power board... this is what you want to check. Second, check to see is the ballast is being given an "ON" signal.. you will find this signal on the same connector or one of the others going to the ballast (some models have 2 connectors from power supply to ballast. The "ON" signal will come on shortly after you press the power button. If you have both, you either have a bad ballast or a bad lamp inside the panel assembly. The lamp.. no fix, junk the TV; the ballast.. you could search high and low for one or try to fix it yourself; no 24v, check with MCM Electronics for a power supply; no, "ON" signal, your main PCB is suspect. I hope this was helpful, best wishes.
Apr 22, 2010 | Insignia IS-LCDTV32 32 in. Television
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
No Signal/VGA Input
use the " input " button on the remote control to select the input you are using to watch tv. she has accidently switched it to the computer input jack which is located on the side.
Jan 22, 2009 | Insignia IS-LCDTV32 32 in. Television
No Signal on HDMI setting
Sometimes the HDMI port can lock up.
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Sep 11, 2008 | Insignia IS-LCDTV32 32 in. Television
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
457 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
