If your Kenwood TS-690S is not powering on, here are some things you can check:
Power source: Make sure the power source is working properly. Check the power outlet, power cord, and any fuses or breakers that might be involved.
Power switch: Check the power switch on the back of the unit. Make sure it is in the "on" position.
Battery: If your unit has an internal battery, check to make sure it is charged and working properly.
Connections: Check all the connections between the radio and any other devices it is connected to. Make sure they are securely connected and that there is no corrosion or damage.
Internal components: If none of the above solutions work, there may be an issue with the internal components of the radio. In this case, it is best to take it to a professional for repair or contact Kenwood customer service for further assistance.
Hi Marty, ..ok, baring anything else acting up, like a airplane before take off , if the audio was working then and not now , you have probably over looked something in pre flight, check all antenna connections, check the external spkr jack your plugged in to , check all buttons, make sure your on a real ch#, check your squelch adjust. and if you changed mikes , make sure its wired correctly for the radio, if there is any other possible human error it's unknown to me. nice radio...gd luck to you...
This is the recommended way to get a solution: join yahoo group specific to your radio Make/Model, give the expert team there as much info as possible regarding the issue with your radio and whilst there you can download manuals, schematics and other great stuff for your radio and it's free to join.
