Question about Acer TravelMate 4072WLMi Notebook
Plugged in my mouse to my laptop, and switched it off of the
Laptop touchpad and it will not work. i plugged it into the usb2 port like i was told, but it is not working. i had to have it backed up and before i had it plugged in to the front port and it worked fine. now the mouse will not work and also microsoft word is not on my computer anymore. how do i get that fixed.
Can not get my mouse on my laptop to unfreeze?
Depends if you are talking about the touchpad or a mouse you added. If it's the touchpad, you might have pressed the button to deactivate it. It is either near the touchpad itself or on one of the F? keys and you need to press a combination of the Fn key and the F? key with the touchpad icon. If it's a wireless mouse, check your batteries, check the on/off switch under the mouse. Try unplugging the receiver and plugging it into another usb port. Try somebody elses mouse also. If it really doesn't move at all, your laptop might be frozen, you can check this by pressing the windows key on your keyboard and if the start menu appears, it'S not frozen and you need to check your mouse or have your laptop serviced.
Oct 08, 2014 | Toshiba Satellite Computers & Internet
Problem with mouse usb
It sounds to me like your USB mouse is not USB2 compatible. Use it while it is connected to the USB3 port. Did it at one time work in the USB2 port?
Mar 19, 2014 | Computers & Internet
I've received my new homeChoice laptop today , I switched off my touchpad and my wireless mouse on but nothings happening mouse aint working and I don't know how to switch the touchpad on again plz help
You can try to plug mouse whit Usb wire, and try to get touchpad on, but if it dosen`t work Disassemble your laptop and get out your Bios battery for some 1-2 min, it might can help.
Nov 15, 2013 | Computers & Internet
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
Mouse pad not working
Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature. Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results. Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked. Hope this helps.
Jan 10, 2013 | ASUS Eee Pc R101d Atom N455 1.66ghz 1gb...
Asus 10065ha xp both touchpad and external mouse not working touchpad went first. then worked with external mouse. then only touchpad. now both not working.
Unplug your external mouse and restart your laptop. Check to see if the touchpad works, if it doesn't reinstall the driver. Unplug all other USB devices and plug your mouse back into a different USB port. It should be detected now. Cheers, Ravi Shanghavi
Aug 18, 2010 | ASUS Eee 4G Notebook
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Aspire 5101wlmi
If you have got a usb mouse plug it into your computer then go to control panel>system>hardware>device manager and go to pointing devices. Right click on the + sign next to keyboard and touchpad, click on uninstall. Then reboot your machine, take the usb mouse out. Windows will reload the correct drivers for the keyboard and touchpad as new hardware and your problem should be resolved.
I hope this helps
Nov 12, 2008 | Acer Aspire 5101WLMi Notebook
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Acer TravelMate 4072WLMi Notebook Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
