Question about InFocus X1 Multimedia Projector
Infocus x1a shuts down after 5 minutes
I replaced main fan; unfortunately, it's still shutting dwon w/ 3 red lights flashing
  • 2,237 Answers
3 red flashing is a lamp error, not the fans. the lamp has a problem striking. make sure it's pushed in and plugged in all the way. if the lamp is not that old, the power supply needs replacing.
Posted on Sep 04, 2009
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Infocus x1a fan replacement
to remove the fan: remove the 8 screws from the bottom of the projector (4 silver, 4 inset and brass) and the 2 screws from the back. pull the back from the bottom, but use a small flat-head screwdriver to release the tabs seen through the topmost vent of the back. once off, unplug the speaker wires on the right and the cable harness on the left. pull the top off while pulling the front off from the bottom. remove the wire harnesses from the power supply board and the ground wire from the power input board. take the 4 screws off of the power input board and the 4 or 5 screws from the power supply board (and 1 center clip) and remove. take out the 4 or 5 screws from the metal shield and remove shield. now you can unplug the fan that need replacing and access the 2 screws holding the fan in. remove fan and replace with a like fan. since the fan speed is not monitored, if you can find one that's the same size, power, and plug size, use it. otherwise, contact an infocus service center and ask them for infocus part # 526-0192-00. reverse instructions to put it back together. but you must remove the front from the top case, put the top on first, plug the speaker and left harness in, then put the back and front on. wasn't that fun?
Jun 02, 2009 | InFocus X1A DLP Slide Projector
Infocus x1a projector shuts down after 30 seconds - dust problem ??
do you have the correct lamp? the x1a takes an sp-lamp-009, that has 2 white wires, and not the more common sp-lamp-018 which looks exactly the same except has one white and one red wire (and are in different plug positions). if it still doesn't light, there is another issue (possibly the colorwheel) along with the lamp timer reset.
Mar 18, 2009 | InFocus X1 Multimedia Projector
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Infocus 4805 problem
Make sure that the lamp plug is properly plugged. 3 flashes indicate this or a faulty lamp.
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
There is a safety themostat inside the unit (looks like a silver button the approx size of a dime) that will shut the system down if you do not have adequate airflow. You can dis-assemble the projector by removing the screws on the bottom and rear of the housing and pressing in the plastic locking tabs inside the cover all around the perimeter but I would advise against this unless you are comfortable with delicate nature of the projector.
Dec 17, 2007 | InFocus X1 Multimedia Projector
InFocus X1 Multimedia Projector Logo
304 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
