Question about LG DLE2532W Electric Dryer
LG DLE2532W NO HEAT
I have a LG DLE2532W dryer that works but does not heat up.The vent is clear and it blows very strong,just cold air.I've tried resetting the circuit breaker in the house and no change.What could it be? I've heard that it could be a thermal fuse or possible heating element.Where are these located and what do you have to take apart? Is there a possible "reset" switch? Please let me know.Thanks.
Mark
  • 1 more comment
  • Anonymous Mar 10, 2009
    Have same dryer and same problem, I read somewhere it could be a $10 part to fix and not the heating element. I can't seem to be able to get the back panel off the dryer even though I have removed all the screws. Is there something I'm missing and where can I go to find a service manual for this unit?
  • Anonymous Mar 22, 2009
    Give up and get professional service. Talked to customer service LG in regards to product DLE2532W. She stated there is no reset button (which I find weird after reading the reviews) I looked for reset button after reading all the reviews and belief there is none for my model. If there is great HELP. If not i think its time to get service.
  • bcjjt Mar 29, 2009
    Dryer runs but does not heat. This is a gas dryer. About two years ago, same thing happened. Called a repairman. He removed the top and the front door panel. He pushed or flicked a switch and the dryer worked great until now - two years later. He told me to do the same as he did if it happened again but did not physically show me the button that he pushed. I know there is something.....help!
  • 76 Answers
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Posted on Feb 23, 2009
Have an LG DLE2532W dryer. It is functioning normally except no heat. The High-Limit Thermostat had no continuity.
Check the vent - if clogged like mine was the hot air generated does not leave and stops unit from working when it overheats. The line and water vapor form a sort of paper mache that effectively blocks the exhaust.
Aug 22, 2017 | LG Dryers
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
My LG Tromm DLE2532W dryer is not producing any heat
heatman101./,'
May 15, 2011 | LG DLE2532W Electric Dryer
I HAVE A FAIRLY NEW LG ELECTRICAL DRYER BUT IS NOT DRYING IS JUST COLD AIR. I NOTICED THAT THE VENT HOSE WASEN'T CONNECTED. CAN THIS BE THE PROBLEM?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | LG DLE2532W Electric Dryer
My LG dryer takes two cycles to dry the clothes
check the dryer vent to make sure it is clear. is there any heat, if not the thermostat or heating coil burned out.
Dec 06, 2009 | LG DLE2532W Electric Dryer
Dryer does not heat model td-v75120E
Hi, open the back panel. You will find a black cutout switch with a red button on it. Press the red button to reset the heating mechanism. Close the back panel and test the machine.
Sep 10, 2009 | LG DLE2532W Electric Dryer
Dryer heats for 10 minutes and turns off
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Jan 29, 2009 | Dryers
Doesnt heat blows cold air
well the first thing that should be checked is resetable thermostat..onthejob
Jan 17, 2009 | LG DLE2532W Electric Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLG5932W Gas Dryer
No heat here either
It appears so. Plugged dryer vent should not cause a problem with control board. Good service tech should be able to use a cordless drill powered brush to clean entire length of vent, providing the vent is not the flex plastic ****. A simple clamp on amp meter test would confirm the dryer element (electric model) to be working. I'd advise you to turn your dryer on and see if you have a strong flow of air out of the outside dryer vent cap. (outside the house, where the bird nest was) Sounds like you could possibly use a new dryer vent cap, with a bird screen cover and a large 4 inch flap. (not the low profile 2 inch flap)
Jul 27, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
1,177 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
