It seems there might be something jamming your disc drive from completely going in, or your disc drive has fallen off the track and might need to be realigned.
The disc is most likely rubbing on the laser lens. The lens is held on rails which is held up by rubber boots that may have came loose and/or popped up forcing the laser lens to close to the disc. Make sure disc tray is aligned properly as well.
To me if you have the old fat PS2's then it sounds like the motors are worn out. You can't fix this unless it's still under warranty and call PlayStation. But if not under warranty, try to seel it to like a pawn shop or something to get cash and I recommend getting the slim PS2. The disc tray pops open like the PS1, and the only thing that can mess that up is it getting something spilled in it to make it sticky. I've had mine for about 5 years now and it hasn't messed up at all. But make sure not to play burnt discs on it or it will get used to them and not play regular discs. Hope this solves!
you are very genious man u think so u put heavey weight on ps2 so you have to put out your cd tray than with helpo of screw driver you open your console than take a tiny thiner than put at this tray of ribbion than wash and clean our disk tray than got new rubber band and some grees and than close your console any try again inshallah you got good result
I HAD THE SAME PROBLEM OUT OF MY PS2 AND MY SON PS2. I FOUND THIS NEW SITE THAT TOLD ME WHAT WAS WRONG FOR FREE AND FIXED IT WITHIN A FEW DAYS.
http://PS2EARTH.synthasite.com I LOVE FIXYA BUT THIS SITE IS BETTER FOR GAMERS. THEY CARE.
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
Disconnect power and turn the case upside down.
Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
Remove all the screws.
Remove the Warranty sticker to the right edge of the power socket.
Turn the PS2 over to set it right side up.
lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
Remove the CD tray lid.
Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
Hook up the power and A/v Cables.
Remove the little white disc from the CD tray lid.
Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
Boot up the PS2 and test it, Continue cleaning until you get it to work.
Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
You must have a Slim model, as only slim models are aggrevating about adjusting and clenaing. If not take a Magnifying glass or Jewelers Loupe to look at the laser lens extremely close.Sometimes it takes a good bit to get it clear.
