Question about Haier XQB60-91AF Top Load Washer
Haier -XQB55-10 water leakage in inlet hose jointer
    Scholar:
  • 106 Answers
Either your inlet hose is blocked or your filter screens on hose as well as machine are clogged. Carefully unscrew to examine and clean out, refit carefully.
Posted on Feb 23, 2009
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Tip
LG Dishwasher Fault Codes
Failure Code > Condition : Check/Repair
  • 1E Water inlet problem > Condition : Not reached to the normal water level in spite of 10 minute water supply. Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
  • OE Drain error > Condition: The drain hose kinked or blocked. Wiring connections. The drain outlet of sump is blocked. The drain pump/motor or circuit is troubled : Remove kink. Check wiring. Measure the resistance of drain motor (20-40ohms) Replace the drain motor or repair the circuit.
  • E1 Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
  • FE Excess Error > Condition : Excessive water is supplied than normal water level (automatically drain pump operated. Possible cause: The inlet valve is troubled,or the controller.Possible cause: The inlet valve is troubled,or the controller. Replace valve or the controller.
  • BE (Thermal error) > Condition: the resistance of the thermistor not normally out put. Possible cause the inlet water temperature is very high(over 194°F) Wiring connections. Thermistor problem.Check temps to dishwasher 120°F needed. Check thermistor 11-14kohms at 77°F. Replace the PCB.
  • LE( Motor error ) > Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
on Feb 26, 2011 | Dishwashers
Water inlet hose either leaks out the top or blows right off when water is turned on.
Yes it sounds like it is. Threads are worn or damaged. Also make sure you have a rubber seal in the end of the hose to stop the leak. Get a new inlet valve fitted.
Apr 11, 2016 | Haier HLP21E Top Load Washer
Haier HLP23E - When I press start, the water flows in and out at the same time.
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Dec 13, 2014 | Haier HLP23E Top Load Washer
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Leaking inlet hose
maybe the pump motor is clogged check that pls.
May 25, 2013 | Haier HLP23E Top Load Washer
My haier front loader was working today then stopped and said error 5 it's model is a hwm1070kFL
The Haier hwm1070kFL error 5 indicates a problem with the incoming water. Either the water pressure is low, any filters in the inlet system are clogged or the water is draining out of the unit (pump malfunction or suction from the drain hose being below the water level in the washer).
The first thing to check is the incoming water pressure. Turn off the valves for the incoming water. Then disconnect the hose from both the washer and the pipe. Check any filters. Reconnect the hose to the pipe and place a bucket below the hose. Turn on the water valve and check the flow rate. (You may want to replace the hose while you have it disconnected. Many modern hoses are designed to seal themselves if they detect leakage. This will stop or reduce the flow of water through the hose.)
Next make sure that the drain hose outlet is 80-100 cm (~32-40 inches) from the floor.
If these steps do not help, you need to check the inlet valve, the pressure sensor and make sure that the drain pump is not moving the water out of the washer during a fill cycle. These may be steps for a service technician.
I hope this helps.
(I live in an area with a rural water district. It isn't uncommon for the water pressure to drop due to problems in the system. Until the maintenance person can find and fix the leak or pump issue, a washer with sensor like this that detects how long it takes to fill the tub will give the low flow error and stop working.)
May 20, 2012 | Haier Washing Machines
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
The panel has a LE ERROR.
LE is an ie .. water inlet problem. ... manual says to check for clogged, kinked, or frozen water inlet hose. check water supply.
OE. Drainage problem
FE excessive water supplied
E1 water leakage problem
HE heater circuit failure
TE thermistor failure, or very high inlet water temp
PF. power failure.
Jun 05, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Haier XQB60-91AF Top Load Washer Logo
123 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
