Question about Compaq Keyboard
Removed fan and heatsink, pins bent. 1 broken on CPU, no display
I cleaned the fan at the power supply and saw that the large heatsink in the middle of the motherboard was very dirt so I removed that and locked it down after placing the pins over the socket which I presume is the CPU which fits inside the heatsink and replaced it after cleaning. Turned on my computer which was running perfectly prior to this and noticed that now there is no display on the monitor and there is a noise coming from the dvd rom also when the pc is turned on. I checked the gold pins under the large heatsink and noticed several bent pins and tried to straighten them but one broke. I replaced the heatsink a couple of times until the power came back to the desktop but there is still no display on the monitor and the dvd rom tray will only open about half way. I obviously damaged the CPU. What can I do to fix it? I read on a site about replacing a pin with a longer cable wire and then cutting it to size to fit. Any ideas? I am a bit low in funds at the moment and I wonder would it be possible to either fix the cpu myself or send it off to be repaired or bring it to a repair shop? My laptop also has a frozen mouse from a dat error. I assume that the registry for the money has been wiped as it says in the reg editor that it has no value. Can I fix it without having to lose all of my files and reinstall Vista from backup discs? Thanks.
  • gadgeto9 Mar 06, 2009
    I have the same problem. My computer was getting noisy so I opened it to vacuum out the dust. I unhooked the fan and when I tried to replace it, it just wouldn't click back into position. I was very careful cleaning the pins, but apparently not careful enough. I think I may have bent a pin. I don't want to mess with it anymore until I find out a solution. Do you know if I can purchase just the heat sink pin thing with the adjoining square pad that attaches to the computer board or do I have to purchase a whole processor with heat sink? Can anyone please help.
  • Anonymous Mar 12, 2009
    I have the same problem. Was blowing out the dust and unhooked the fan and i guess what is the heat sink and cpu? and could not get it back in. A few pins bent but fixed them. Put it all back in computer came on fine but no display no clue what to do now!
    Top Expert:
  • Compaq Master
  • 26,637 Answers
New CPU required.
Posted on Mar 01, 2017
  • 231 Answers
SOURCE: d530 CMT minttower power problem
Hi, from your description it appears your power supply is ok.
Remove your RAM chips, clean everything with a soft brush or a can of compressede air [from computer store] Reinstall the RAM making sure it is seated firmly.
If this does not solve the problem, Are you using 1 or 2 RAM sticks? if 2 then remove them again and swap them around.
stick one in dimm2 and stick 2 in dimm 1.
If you only have one stick then beg or borrow another stick and try it. If all fails you may have developed a mobo problem.
Regards mistyman
Posted on Oct 15, 2007
SOURCE: Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Posted on Dec 28, 2007
djnick989
  • 1067 Answers
SOURCE: Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Posted on Jan 07, 2008
myob247
  • 1342 Answers
SOURCE: Remove keyboard on compaq presario 700...
Look for 4 tabs on the top edge of the keyboard. Use a small flat head screwdriver or something similar and pry forward.
Posted on May 03, 2008
SOURCE: Turns on, then shuts down before anything shows on monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Posted on Jul 25, 2008
My Compaq Presario SR1303wm PP150AA cuts off by itself and a little green light on the back starts blinking
it could be overheading or it could be a power supply going bad. where is this green light, is it adjacent to the power cord, like on the back of the power supply unit, or is it adjacent to all the ports?
if the light is on the power supply then replace your power supply. if the light is adjacent to the ports, then remove the side cover of the case and blow the dust out of the cpu heatsink (the cpu heatsink is pretty big, usually aluminum, fin array, topped with a large fan). do not touch any microchips inside the computer, and discharge any static electricity before acessing the inside by touching an unpainted part of the case right after you have removed the side cover. if the heatsink is not dirty, and all the fans are working and well ventalated, then it is likely the power supply.
Mar 12, 2011 | HP Compaq Presario SR1303WM (PP150AAR) PC...
I put a new power supply & heatsink with fan in my system & now I can't get it to power on. The heat sink was VERY hard to get on. I even put the old power supply back in & it won't power on....
If your CPU is sticked on the heat sink due to heat sink cement, could have damaged your CPU pins. Those CPUs like AMD and IBM Desktops we need to unassembled the same by tilting method. If your CPU pins are damaged, remove your CPU from heat sink by the help of a chisel type screw driver and clean both faces of heat sink and CPU. Do not scratch, use isopropyl alcohol to remove heat sink cement. Inspect any pins are dented or damaged. Align pins, if broken solder with help of a goldsmith. Reinsert the CPU in motherboard socket, apply a little portion heat sink cement in cpu face and re fix heat sink and recheck the motherboard.
Feb 12, 2011 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Asus M4A785-M will not post. I have completely removed motherboard from case, removed all components except CPU (AMD Phenom II X4) and CPU cooling fan. When power supply (which I tested in seperate...
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Dec 12, 2010 | ASUS M4A785M (890552666775) Motherboard
Is it possible to put the cpu back in the wrong way? i have just cleaned my comp & i removed the fan over the cpu & the video card? i put them back & now i cant get a signal to my monitor could...
If there is no activity when you power up then it could be the CPU.
Remove the CPU and check the CPU to see if you have not bent any pins. The CPU can only be installed in one position.
The CPU when removed usually sticks to the heatsink.
The CPU should be removed off the heatsink.
The CPU is locked onto the CPU chip holder, lift the locking level up to release the CPU or there may be a locking screw instead of a lever. Turn the screw anti-clockwise to release the CPU lock.
Insert the CPU in the chip holder and lock the CPU in place. If it a screw lock then turn the screw clockwise to lock the CPU in place.
Smear some fresh heat sink compound on the CPU and heatsink and place and then lock the heatsink in place.
Sep 25, 2010 | Medion (40010998)
I have a Lenovo 3000I have a Lenovo 3000 J115 7387-A32, I replaced the AMD athlon 64x2 Dual-Core 3600+ with a AMD Athlon X2 5000+ 3200mhz Scoket AM2+ CPU, when I turn on the computer the fan in the power...
I think the first thing to do is go back to the cpu Fan and check the plug and make sure you are on the pins as should be make sure that there isn't any Bent pins . Continue on to the next fan in question.If not then I would not continue Running this machine Until I had the fan problem fixed. It doesn't take long to mess things up. I am surprised that it will run . I would like to have faith in the hardware monitor to propely shut it down.then I would go to the power source Plug on the motherBoard . Check that it is connected good and try it for a short run on then off to make sure that the fans are running like they are supposed to.
Nov 19, 2009 | Computers & Internet
Monitor screen just E coming .
memory is the main problem if you have two in two slots remove the one which is away from processor if no results remove both , clean the pins well and re insert.one // if no display remove and put another one ..it has to work
if it doesnt then processor is heating up excessively because the cpu paste has dried up which is found between the cpu and heatsink fan
Sep 19, 2009 | E-Machines Emachine T5026 power supply **...
Emachine t5230 cpu fan too fast
Hi orinzelenak,
This may seem like to simple, but try checking to see if the technician plugged the fan power supply into the correct pin for it. It sounds like the fan is plugged into a external plug directly from the power supply and not into the board, which would control the fan speed for you. Give a look, and maybe it's just that simple.
Good Luck
Mark
Jan 04, 2009 | E-Machines T2682 (000002965) PC Desktop
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Compaq Keyboard Logo
9,942 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
