Question about Lexmark P4350 All-In-One InkJet Printer
My printer will not print from computer to printer ,
Because i have Vista
  • 530 Answers
Hi im josh in cebu phils. friend if your printer wont print with vista software.please try to re install your printer then if ask to block with vista programs frewall etc.please choose allow installation and connection so that it will provide you the complete acces. good luck.vote me so tht i wl know if i helped you.
Posted on Feb 23, 2009
I've never been able to print using the a920 on my computer using vista. It prints perfectly on other computers, though. It starts up, acts like its printing a page, but the page comes out blank. In fact...
u need to uninstall the drivers for the printer on ur vista computer,.. go to the following link and download latest vista drivers..
it will work..
Dec 20, 2009 | Dell A920 InkJet Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
I have a HP VPavillion computer with Vista and an
Vista is tricky like that. do you have the cd that came with printer try to reinstall it. maybe go to HP site update the drivers.
Jun 10, 2009 | HP DeskJet 950c InkJet Printer
Colors out of computer aren't the same out of printer
When you print a test page, do all 3 colors show up? If they don't your cartridge is out of one color, or the print head for that color is cloged. When you install the printer on Vista, if you are using a USB cable, bring Vista all the way up and then plug in the USB cable. Vista should then tell you it found a new device. If it does, the Vista probley has a driver built into Vista. If it askes you if you want to use the existing drivers, say no and chose the drivers from the Vista printers.
Mar 04, 2009 | HP OfficeJet D135 All-In-One InkJet...
IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Feb 19, 2009 | IOGear GPSU21 Print Server
Printer printing backwards from all computers but one
Welcome to Vista! I have been sending documents to an XP desktop to print because My Vista laptop prints mirror image...
Dec 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
