Question about Maxtor MaXLine Plus II 250GB 7200 RPM Portable External USB (250GBEXT) Hard Drive
Hard drive wont show up
How do i get my 250 maxtor hard drive to show up. i put a password on it from another pc but it wont show up on this one? what is the problem?
    Problem Solver:
  • 8 Answers
Change the jumpers to slave if it is on the same cable as the master should show up
if it is set now on master it wont show up
Posted on Feb 24, 2009
I Have a Maxtor blackArmor personal storage drive. I have forgotten the pass word to it. It wont let me change the password without knowing the original password. It has our family pictures on it tha
Well, according to Maxtor, there's nothing you can do to recover the password. I suppose that's the point of having a secure drive like that. Here is an excerpt from their FAQ:
"What do I do if I lose or forget my BlackArmor drive's Password?
There is no way to recover a lost/forgotten password. In the event that this happens, you must perform a KeyEraseTM using the Maxtor Manager software. Once erased, you will have to reconfigure, repartition and reformat before redeployment/use."
Maxtor BlackArmor Frequently Asked Questions
Oct 31, 2014 | Seagate Maxtor BlackArmor 160 GB USB Hard...
I click safely remove hardware and pluged my hard drive back in the USB port my computer will not put it back online
reboot the PC with the drive connected and powered on.
Navigate to commputer management/drive management and make sure the drive is online.
Jan 30, 2010 | Maxtor MaXLine Plus II 250 GB Hard Drive
I can't access the hard drive
You will need to initialize it from the Disk Management. To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right.
Right click on the drive and a window will popup. Select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
If you need further assistance, just let me know.
Oct 03, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Beeping, not showing on computer
Its beeping because its damaged! sad to say but the beeping is an error code! the other downside is hard drives are hard to repair so you may need to buy a new one.
Jun 18, 2009 | Maxtor BASICS Personal Storage 3200...
Drive Wont format
First, because they came from the Lacie external drive, they were raided to look like a single drive. To format them inside your computer. You have to go into computer management to initialize each drive at a time and format them by right clicking on the drive and format
May 06, 2009 | Maxtor Hard Drive
Only 32 gb of 250 gb hard drive is reconized
Hey,
If you look at the jumper settings on the drive, they are near the power connector and data cable, then look at the jumper info on top of the drive. I think the jumpers are set to limit space 32GB.
Adjust the jumpers.
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Maxtor Hard Drive
My maxtor wont work at all
It could be a couple things - do you still have the Maxtor software installed on the PC? If not you may need to reinstall the software because it may be a password protection issue.
If that is not the case the drive could be damaged. If damaged you may or may not be able to recover the data. Try downloading a product I have used before from Easeus (http://www.easeus.com/). Its drive recovery software and may locate the drive when Windows cannot.
If that does not work you may need a professional to repair the drive or recover the data.
Dec 09, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
If this is a Maxtor drive that you password protected and now you can't get it to work on another PC or new hard drive. I had the same problem. Fortunatly I had set it up on another PC prior to setting up password protection, so when I tried it at work I discovered that the software will not even load on the PC becuase of the Password protection. If possible you need to use the hard drive that it was first set up and turn off the password protection. Then it should work on any PC.
Nov 10, 2008 | Computers & Internet
Unable to brows the Maxtor External HDD
Hi
If the password is ATA then you will not be able to gain access to your user data without either knowing it or having the tools which can access the HDD in the SA and not user area.
You may need to speak with a DR firm for advice.
May 28, 2008 | Maxtor Hard Drive
Maxtor MaXLine Plus II 250GB 7200 RPM Portable External USB (250GBEXT) Hard Drive Logo
193 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
