Question about Technics SA-DX1050 Receiver
Sound is coming from the surround sound system but not from tv
Sound is coming from the surround sound system but not the tv... the reciever says tv... is there not suppossed to be sound from both the tv and the system? How do i fix this problem? I have the tv hooked to both the tv and the dvd player but still nothing... and the same problem is happening when we have the dvd player on... sound from the system but not out of the tv... can you please help us?
  • 77 Answers
if you have sound from the tv aswell you will experience a slight delay in the audio.....
do you have audio from the tv to the system ?
Posted on Feb 23, 2009
I have a lg 60 inch i tryin to get the sound to come out of the surround system
connect the audio out of the tv to any input of your surround reciever. ou can use optical out from tv or analog out. then select that input on the reciever. you can go into tv menue and turn off the speakers in the tv. Recommended.
Aug 30, 2011 | LG 42LG50 42 in. LCD HDTV
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Connecting LG 42PG20 TV to Samsung HT-Z320 receiver
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Oct 15, 2009 | Samsung HT-Z310T Theater System
I have an LG LED TV and Samsung 5.1 Surround sound and when it comes to Blu Ray movies I get sound, but I don't get the surround sound through cable or XBOX 360, the only time I do is through the TV when...
the very best and easiest solution is have every input into your tv, and your TVs audio out (RCA/Optical) into your reciever. this is a variable audio (Meaning you can only listen to your reciever with your TVs audio up) or you can turn off the audio completely in your TVs soiund properties.
hope that helped :) -Jordon
Aug 27, 2009 | Samsung Audio Players & Recorders
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
Connecting surround sound system
get a reciever and then get componet cables then hook it all up through the hdmi cables
Jan 22, 2008 | Sylvania 6727DF TV
Connecting up
Easy set up, Hook up all the components to the back of the TV normally and then use a stereo cable from the tv to your reciever.
Usually on the tv it says audio out or variable audio out, this will go straight to your reciever on one input allowing all devices on your tv to be hooked through your reciever on one cable and the sound will come from the tv and reciever at the same time or you can turn the audio off on the tv., you can also hook up any optical audio outs from your devices to your reciever as well. This will allow for surround sound to your reciever.
Dec 21, 2007 | Televison & Video
No Sound
bring up the menu and activate the skeakers on/off feature ,also look in rear for internal/external switch .
Nov 27, 2007 | Toshiba 55H70 55" Rear Projection...
Tv surround
It depends on what you currently have as equipment.
You'll have to have something that outputs in digital audio (coaxial or optical). Either your reciever (Cable/Satellite) or the TV. You'll just hook that up to the Surround Sound unit and then just turn on the Surround System when you want surround sound.
You'll have to connect the TV as you would normally with audio cables sicne you'll want stereo sound on the regualr channels.
Nov 22, 2007 | Sanyo DWM-2600 System
Technics SA-DX1050 Receiver Logo
247 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
