Question about Maytag Atlantis MDG7400AW Gas Dryer
No heat coming on in gas dryer Maytag Atlantis
No heat coming on in dryer. Not the usual sound of ignition firing cycle. Dryer does tumble clothes. Easy fix ??
  • 1,800 Answers
Inspect the ignition switch
test it continuouty using th multimetrer if it defective a replacement is ezquired
Posted on Feb 23, 2009
  • 744 Answers
Hi.. check whether the the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on then it would start by changing the gas coils... changing the gas colis will solve ur problem..
thank u!!!
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
My dryer turns on, will click then the fire ignites, but goes out after a few seconds, so it is not staying on, and it takes two and three cycles for my clothes to dry, is it the igniter?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
The Atlantis Gas Dryer comes on, heats the clothes, but will not tumble the clothes so that only the outside of the clothes are dry.
hello,
I believe the the problem with your dryer is a broken belt this youtube i have attached will show you how to replace it
http://youtu.be/6ufArteqWXk
Jul 23, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My Maytag Altanis Gas Dryer, does not heat for the whole cycle.
replace your gas valve. not opening up completely. check wires for good connection inside the male and female harness
Jun 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer MDG5500AWW will not heat. Tumbles but no heat.
Could be any number of things .. igniter ( which lights the fire that dries your clothes) over-temp switches ( that disable the gas valve from opening and won't let a fire get started..) Defective gas valve.. not opening to let gas in for the fire that dries our clothes..
Those are the main components in your system and not much more I can provide to you unless I had specific details on what you've checked etc.. maybe this link will help identify the parts associated with your dryer... and if your so inclined..can do your own diagnostics... http://www.pcappliancerepair.com/model-display.php Hope that helps...
Aug 24, 2008 | Maytag Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
50 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
