Question about Korg Legacy Collection
Intermittent problem with an electric piano.
While playing instrument, sound will either suddenly seise or the last note played will sustain and reverberate indefinately even when key is released. turning keyboard off then on again resets most of the time, other times keys produce no sound. Intermittent= one second to hours between glitch. Note of interest; instrument performs flawlessley while controlling other synths thru midi. any ideas?
  • 4 more comments
  • lshover Feb 23, 2009
    piano is being played through an amplifier, not a computer.
    no good.more answers please/
    this is a korg sg-1d sampling piano,top of the line classic at its best, indebth knowledge answers only please.
    not a power supply problem, more answers please.
    this problem has nothing to do with the legacy, this unit is apprx 20 years old, it is played through an amplifier, not a computer.
    sounds probable except the fact it plays perfect while controlling an e-mu proteus 2000. keys work fine.
  • 547 Answers
Look in synthesizer settings for lenght of last note played thank you for useing fixya please rate me
Posted on Feb 23, 2009
  • albert getty
    albert getty Feb 23, 2009
    Korg Tech Support 631-390-8737 (1 year parts and labor) Register online within 90 days for 2 year parts and labor warranty (for keyboards only) Korg Website as you might not find any held call tech support thank you for useing fixya
    Master:
  • 416 Answers
It sounds like a keybord failure. The keys of the keyboard can wear out over time. This might result in keys that don't make good contact (you have no sound) or that remain in contact (last note played will sustain ) even when pressure is removed. Probably there is no easy solution for that. I may suggest to disassemble the unit and clean the contact surface under the keys and keys itself with degreaser (40 % ethyl alcohol or 70 % rubbing alcohol) and let it dry for couple hours or dry it with hair dryer. In most cases it helps. If no help you need to replace the unit
Good Luck
  • 54 Answers
I suggest you reinstall your software using this web site you may have gotten a bad install:
KORG Templates
PC:Software:KORG.ZIP
MAC:Software:KORG.hqx
KORG Templates
This download contains Template Scene Data that can instantly configure the KONTROL49 to provide real-time control of the Korg Legacy Collection (KLC-1); the MS2000 (all flavors: 2000, R, B, BR) the microKORG; and the EA-1 and ER-1 Electribes.
The KONTROL49 can even control an EA-1 and an ER-1 at the same time - knobs and sliders to the EA-1, Pads to the ER-1, etc.
This data can be loaded into your KONTROL49 using the Editor / Librarian program on the CD-ROM included with your KONTROL49. A separate Scene Set file is included to load all the KORG scenes at once.
Also included are .pdf documents showing the controller and port assignments, so you can print a hard copy for reference.
In addition, you'll find "Read Me" files in this download. Feel free to go ahead and read these documents to enjoy this download to its fullest.
Please note: This data is the same as that provided on the CD-ROM included with your KONTROL49
  • 530 Answers
Hi im josh in cebu phils. Friend if that happens maybe there's a shorted parts inside try to check if it wasn't poured with water.check if it is not wet.because it can damage the kboard.the pblems you've mentioned is a symptons of wet unit.so do something to check it out. try also to check the connection of the power supply or cable.attached it firmly to give enough powr to play your unit. good luck.please vote me so tht i wl know if i helped you.thnks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, I would suspect the effects processor rather than the keyboard itself.
If you are considering a DIY (do-it-yourself), the unit must be opened to access the effects processor board. It is also required to have familiarity with electronic components (digital & analog) and circuitry, use of a DVM, logic probe and even a soldering iron. Access to a service manual would be to your added advantage or at the very least a schematic diagram. Of particular interest to your diagnosis would be the phase shifter and the effects generator/processor.
Should you be uncomfortable performing a DIY, then perhaps your best bet would be to seek the services of a qualified professional.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 23, 2009
    The service manual would provide you with the block diagram, the signal flow, where the PCBs are located, test modes, function test, how the MIDI is implemented and therefore why the MIDI is good but analog audio has intermittent issues. Service manual maybe purchased from here and/or here.
  • 1,800 Answers
U can inspect two things in this case:
the
  • Jalal Sordo
    Jalal Sordo Feb 23, 2009
    sorry
    u shud inspect humidity under the keys on the board.
    or firmware is corrupted= downlod and flash it with latest firmware from the support and dwonload page of ur product!
  • 265 Answers
Yes this is because you are not connecting it to a computer that has a USB 2.0 port, you are using a USB 1.
USB 2.0 is a much faster connection just like firewire.
so your only option is to use another computer, a new up to date one.
hope this helps
alex
When I hold in C and then press Csharp in the same octave,the C-sharp goes silent.It goes the other way around as well.They work when I tap them separately.And that problem occurs in every octave of the...
It sounds like the piano is in mono setting. One note at a time can be played. Find out how to set it at poly mode, allowing multiple notes to be played at the same time.
Jul 09, 2014 | Yamaha P-155 Electronic Piano
Playing certain 3 or 4 notes at a time causing sound of one or more extra notes.is there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Sep 06, 2012 | Yamaha P95 Digital Piano
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
My P85 digital piano have not a good trasmission with midi cable USB, in particular when press the sustain pedal trasmit a note to pc. Thanks
It is IMPORTANT to realize that the SUSTAIN is NOT attached to a note, but is an independent MIDI message. Hence it is up to the external MIDI device to associate the sustain with whatever notes are still active.
Feb 27, 2011 | Yamaha P85 88Key Portable Digital Piano
There is a tinny unpleasant sustain in the high notes with or without pedal. Is there an adjustment to mellow this sort of ringing (the keyboard is set all the way to "mellow") we tried...
Some of the Yamaha pianos have several pianos emulated and selecting a "Grand" will sound different than if you select an "Electric" or "***** Tonk" setting.
There is NO internal adjustment for this. other than the voice selection. Choose either the Grand1 or Grand2. Do not use reverb as this can "ring".
Feb 14, 2011 | Yamaha YDP223 Digital Piano
Piano has a ringing sound when playing keys
Check if the sustain is stuck on due to a bad pedal or lack of.
Also some settings like Harpsicord have a sound that has ringing... check you have the correct voicing.
Dec 08, 2009 | Music
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Computers & Internet Logo
74 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Hardware and...
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
