Question about Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater...
Gas tankless water heater turns off during shower
While taking a shower our tankless water heater sporadically turns off, even the pilot light. It has happened 3 times now over about a 2 week period. Relighting the pilot will get it going again.
It is a Bosch 125B manufactured after Feb 2005..
I think it is the thermocouple since it turns off the pilot as well as the main burner. It could also be the gas valve.
These parts are expensive and non returnable so I would like to get it right the first time.
    President:
  • 2,692 Answers
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Posted on Feb 23, 2009
I have a bosch aquasar 125b tankless water heater and the burners do not light when hot water is turned on this also causes the pilot light to go out
possible faulty pressure switch connected to the water line and that is failing to turn on the main gas tap solenoid
best have it checked by an accredited gas fitter or service center for the make
Aug 20, 2016 | Bosch AquaStar Indoor Natural Gas Tankless...
Once in a while after burner has been on and shower has been on for a while, the burner shuts down and pilot flutters, then pilot comes back on good but no burner .eventualy burner comes back on. if i turn...
Probably the burner and parts need to be cleaned yearly as recommended in most gas water heater manuals. Both tank and tankless today recommend same.
Open following link for Bosch troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 20, 2011 | Bosch AquaStar Natural Gas Tankless Water...
Failing ignition on Bosch Aquastar AQ125-HX tankless on demand water heater. Carefully followed all directions on device to best of ability. Gas supply is full and on. Water pressure should be...
Before calling service technician, open following links for Bosch troubleshooting resources:
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Paloma Tankless water heater wont kick on
Tankless Water heaters have a automatic pilot and digital water temperature control system; you have to turn on the water in the house to get it to kick on that is unless you have a circulation pump on a timer. If the gas supply doesn't have atleast a 2" rating that with cause the tankless to malfunction because it's not getting enough gas pressure; certified professionals rarely make this mistake. Moreover, if you don't have a water softener you are using with the tankless you voided your warranty; the minirals clog the heat exchanger.
Nov 25, 2008 | Water Heaters
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Logo
467 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
