Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not stop -- door locked, and it is stuck in the drain
Cycle, but the drum does not spin. The timer flashes, but does not count down. Pressing pause/cancle has no effect. I have unplugged it for 30 min., but this did not reset the issue.
    Problem Solver:
  • 6 Answers
Had the same issue with my whirlpool front load washer and it turned out to be the water pump. Believe it or not it turned out to be pricey (about $280). The service guy said that the this was a common problem with these new front load washers.
Posted on Feb 23, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Stuck in spin cycle
The heating element maybe faulty,
or even the thermostat .
If one is not working,
and the temperature does not get to the required temp,
the washer reboots, and tries again,ect
Nov 19, 2013 | Washing Machines
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
Kenmore Model 80 get stuck after agitate and will not spin out
I have seen this on the same model recently, try lifting the lid during the neutral drain and reclose, if it engages spin then. then most likely your timer is bad too. The timer after two minutes of "neutral drain" will stop the motor (same effect as lid sw) then restart after a pause with spin/drain. this pause shifts the transmission to its next cycle which is spin. I found burned contacts in timer. Your timer list price is over $100 but easy to replace
Nov 24, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Kenmore he2 front load washer
    remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
    Jun 02, 2008 | Washing Machines
    Washer won't run....
    It seems as an overload issue. The machine has an overload switch to protect the motor. Take the comforter out and operate the machine,it should work fine. Good luck!
    Sep 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    120 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
