Question about Jenn-Air JCD2389G Side by Side Refrigerator
I have a Jenn Air JCD2389GE Side by Side. My problem is that at random times (once, twice a week and sometimes once every two weeks) a puddle of water is on our tile floor just in front of the freezer side. There is also a frozen layer of water on the bottom of the freezer floor and a little frozen water at the bottom of the white coil cover on the back of the inside of the freezer. Anyone know what this one is? Thanks in advance!!!
  • Mike Van May 11, 2010
    Also turn up the temp on your freezer so it won't happen again. Your freezer setting was probably too cold!
  • 410 Answers
You have a frozen defrost drain. whenever the unit goes into defrost, usually once a day the water instead of running down the drain is running out on the interior and then onto your floor.Fairly easy fix if your game?
  • unplug your refrig
  • remove all food from interior of freezer
  • remove shelving
  • remove 2 screws holding the rear cover in place these are usually painted white to blend witht he cover. btw this is the lower cover so you do not have to remove icemaker or dispenser bucket.
  • once cover is removed defrost all of the ice that you see with a hair dryer
  • once the ice is gone you will see a drain hole in the center beneath the cooling coil ou need to flush hot water thru this hole to clear any ice and sludge that may be in the line. ( I sometimes have to use a syringe or turkey baster filled with hot water to forcefully clear this line)
  • reassemble in reverse order
If you have any further questions or comments leave them here and I'll get back to you. Thanks Peyton
Posted on Feb 23, 2009
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
My Jenn Air Dual fuel slide in Range (2003) Mdl JDS9860AAB Resets itself as if it had lost AC power. This happens about once a week. or if I am cooking an important meal (like Thankgiving) It resets itself...
Main micro-processor, clock control defective, replace clock control or it power supply board. It's recommended to replace power supply & control if this unit has the two on seperate boards.
Sep 30, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
I have a JENN-AIR side-by-side refrigerator Model # JCD2389GE. The freezer side works great but the refrigerator side barley gets cold. Help!
the damper on the left corner in the refrigeartor is not opening is either blocked with ice or broken also when the frezeer is not defrosting like it supost to it blocks air circultion to fresh food section check both thing damper and defrost
Nov 09, 2008 | Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Logo
315 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
