Question about GE Spectra JBP78 Electric Kitchen Range
Self cleaned and now latch wont open
Self clean
  • 3 Answers
I have a whirlpool range , and on the top part where the touch buttons are it apperas eED-F3- AND THE OVEN DOOR IS LOCKED, THANK YOU PLEAS HELP
Posted on Feb 23, 2009
Door won't close due to latch being in lock position from self clean mode, pulled to check door and latch activated while open. How to latch to move.
Have you tried put it back I clean mode it might reset it self.If work let it finish cleaning this time please.
Dec 18, 2014 | Kitchen Ranges
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Self cleaning light flashing oven wont work. model 362.72498991
this is going to have to do with your latch assembly. The door thinks that's it's both open and latched at the same time so it's waiting to self clean. Here is the part to order. Check the latch switch. Here is the part if you should need to order it.
Dec 08, 2012 | Kenmore Kitchen Ranges
Error code E-1F5- came up on self cleaning oven before cycle was done what does this mean door wont open
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 20, 2011 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Oven sef clean latch locked but door is open and I cannot clos it. I inadvertantly urned it to self clean and openedthe door and the latch is locked in self clean position. How do I release the latch so I...
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Jun 16, 2010 | Kitchen Ranges
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Good Morning: The self cleaning mode engages, locks the oven on the bottom, but does not clean. On the top, the latch does not engage at all on the self cleaning mode. What to do?
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Mar 27, 2009 | Viking DEDO205 Stainless Steel Electric...
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
125 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
