Question about Palm Zire 71 Handheld
Zire 71 Camera
I have a new (several years old) Zire 71 PDA. Several problems #1 cannot get the camera to work & #2 I cannot find any instruction booklet. Does this item have the ability to shut itself down before the battery goes out and then looses it's memory.? Thank you for any help
  • 38 Answers
1) The camera is most likely broken- unless you are handy dont bother trying to use the camera
2) The booklet isn't all that useful but you can find a copy of it on Palm's website as a PDF file
3) It will turn off and a prompt will warn you of the low battery, but if you continue to turn it on it will "forget" everything in memory
I hope this helps and I hope you enjoy your Zire - it is a good PDA
Posted on Mar 11, 2009
I replaced the Battery in my palm Zire 71 and two pieces that fell out and then when i put it back together with out them the camera wont come on at all I have the pieces but I just need to find out w
You aren't going to find that information anywhere. My advice is to either return it to Palm, or buy a spare one. There is one for $4 that needs a charger.
Palm Zire 71 Repair
Palm Zire 71 Take Apart Directions - DirectFix
www.directfix.com/category/_ZIRE71_TAKE.html
iPhone Replacement Parts? We offer iphone parts for cracked iphone screens. DirectFix offers iphone screen replacement parts, iphone repair parts & iphone ...
Palm Repairs ' palmdr.com
www.palmdr.com/pda-repair/palm Tungsten T, T2 and T3 Repair Form. Zire Series Models Zire 72 Choose either our Repair Form or Express Repair Service Zire 31 Repair Form Zire 71, Zire 21, ...
Zire Series : PalmDR.com, PDA Repair Done Right!
www.palmdr.com > Home > Accessories Products 1 - 12 of 27 - PalmDR.com : Zire Series - PDA Units Accessories Printers Repair ... Perfect fit screen protectors for your Palm Zire 71 or Zire 72 PDA unit.
Palm Zire 71 PDA for Parts or Repair • $4.00 - PicClick
https://picclick.com/Palm-Zire-71-PDA-for-Parts-or-Repair-192159832687.html Up for auction is a for Parts or Repair Palm Zire 71 PDA for Parts or Repair This is in excellent physical condition but I do not have the charger 192159832687.
Palm Zire 71 PDA for Parts or Repair 805931008343 ' eBay
www.ebay.com > ... > Gadgets & Other Electronics > PDAs > See more Palm 71
Rating: 4.5 - ‎80 reviews
This is sold as is for parts or repair. This is in excellent physical condition but I do not have the charger to test. I do not know if the battery is good or bad or if it is ...
Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair
www.ebay.ca > Consumer Electronics > Gadgets & Other Electronics > PDAs Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair in Consumer Electronics, Gadgets & Other Electronics, PDAs ' eBay.
Jul 25, 2017 | Palm Zire 71 Handheld
Palm zire 71
Install Documents to go software...a version comes with the intial CD. It can also be purchased on line through Dataviz.com..the best software for reading officefiles on a PDA
May 27, 2009 | Palm Zire 71 Handheld
Palm Zire 71 handheld does not come on, did a hard reset, nothing
Confirm that both the cradle and the PDA ports are clean and free of dust or dirty.
Also, check your AC wall adapter to confirm that is working. The output should be +5.0 volts DC. Any repair shop has a multimeter need it to check it in no time.
If everything appears is OK, then confirm the PDA is properly placed in the cradle, and that the PDA is not loose on the cradle, indicating that the port contacts are not touching.
Best regards,
Mar 24, 2009 | Palm Zire 71 Handheld
Palm zire 71 replaced battery camera and charging port not wrking
Dis you see if either the brown plastic locking part of the connector is broken or missing?
Do you know if the soldering joints and terminals of such connector are in good shape?
I am asking because it may be only that the flat ribbon cable is nort placed properly, or such flat ribbon cable is damaged.
Also, the connector at the mainboard can be damaged.
Depending of what is damaged, it will be the cost to repair it.
I do recoomend you to disassembly very carefully your pda again, and check such areas and parts.
If you find something that is broken, you can get the needed parts from a broken PDA in Ebay or similar sites.
Best regards,
Dec 22, 2008 | Palm Zire 71 Handheld
Zire 71 screen
Two possible scenarios:
1. Loose LCD screen connector inside the pda. You will need to open it and put it right.
It requires some level of skills to open it, repair it, close it properly.
If not precautions are taken, there are two major risks:
a) Break the flat ribbon cable of the universal PalmOne port (used to synchronize it and charge it).
b) Break a tiny switch that detects when is slided the top side so the camera application turns on.
2. LCD screen is damaged. It needs replacement.
You can get in touch with local repair services for it, and request a quote for its diagnostics and repair.
If after get some quotes, you think that they are excessive, you can contact the Ebay seller Great_items_2004 to receive a lower quote for it.
Regards,
Jul 08, 2008 | Palm Zire 71 Handheld
No display
Hello LyMaBa
Do you have an SD card inserted in the PDA?
If so remove it and restart your PDA.
Did the problem go away. If so, please, go HERE for the Zire 71 Expansion update or HERE for the SD/SDIO update.
You can find all the manuals for the Palm Zire 71 PDA HERE.
If you don't have a SD card inserted, you might want to try performing a WARM RESET of your PDA. Youtube has a video on this process HERE.
You can find instructions HERE for performing a reset ("warm" or "hard") on your Palm PDA.
You can find other software, info, downloads, etc.
HERE for your Zire 71.
If performing a "warm" reset doesn't work, try performing a "hard" reset.
*** WARNING!!! ***
YOU WILL loose ALL of your data on the PDA by performing a "hard" reset so make sure it's data has been synchronized w/ your computer software (Palm Desktop, Microsoft Outlook, etc).
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Apr 09, 2008 | Palm Zire 71 Handheld
My palm zire 71 does not ever synchronise to mi laptop
You can check in PalmOne web site the user manual for such PDA.
There are all the instructions in how a synchorinzation is done, and how to add new applications to it.
Best regards,
Jan 20, 2008 | Palm Zire 71 Handheld
Palm Zire 71 Display Problem
If you slide your Zire up as if you are using the camera, there is a reset hole in the back that you can poke a needle or pin into to have it do a "reboot" which will not lose data.
Not sure why the display changed.
Dec 29, 2006 | Palm Zire 71 Handheld
PDA is totally black; not charging
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
Nov 14, 2006 | Palm Zire 71 Handheld
PDA is totally black; will not charge
Please see the following link to locate the reset hole for your PDA. http://www.palm.com/us/images/support/kb/articles/hs/30113_Zire71.gif Try a soft reset and let us know if that helped with anything.
Aug 14, 2006 | Palm Zire 71 Handheld
Palm Zire 71 Handheld Logo
137 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
