Question about Whirlpool LEN2000PW Dryer
My Whirlpool Imperial (Accudry) is not receiving power
My Whirlpool Imperial (Accudry) is receiving power (240v) up to the cord post, which looks good and the screws are tight. The dryer is 8 yrs. old. The dryer does not turn on, the light does not come on, the timer is no clicking. The fixed thermostat (AP3131941), thermal cutoff (AP3094244) have continuity and internal thermostat (AP3045874) outer posts have continuity, but the inner posts do not have continuity. Could this inner thermostat cause the dryer not to have power?
    Genius:
  • 1,122 Answers
MOST OF THE TIME IF NOTHING WORKS IT YOUR DOOR SWITCH,OR YOUR MAIN WHITE FUSE ON THE BLOWER BOX,LET ME KNOW-MIKE
Posted on Feb 23, 2009
K&K AT-306 RECEIVER THE POWER CORD IS A two prong ,i think its from uk{ can i use this Uk to US USA Power Adapter}or soilder 110 power cord on the motherboard
The UK have 3 prong power plugs. Your power cable may be a figure of 8 type, Readily available in most electronics stores. If it states 240V only, then that is the voltage it needs.
Jun 13, 2016 | Computers & Internet
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Doesn't automatically turn off in accudry sensor
yes,the moisture sensor bars inside the unit can be replaced,you need to tear down part of the machine to do so,to further assist you,a model/serial# would help
Jul 17, 2010 | Whirlpool Dryers
My Whirlpool dryer LGT7848AQO imperial series does not heat up. HelP!
Check the fuse/circuit breaker box, you need 220/240V to heat the dryer. If there is proper voltage going to the dryer, then you will need to goe inside and check the limiters and element.
Feb 17, 2010 | Dryers
I went 2 turn my elect whirlpool dryer on,1st it tripped the breaker,i flipped it & it will nt start up,its getting power..though
if your getting 240v to your dryer but will not start and is tripping breakers there are a few things this could be I would start by making sure your cord is in good condition and the terminal block where the power cord is connected to does not look burned or at your wall plug.
Feb 23, 2009 | Whirlpool LER4634J Electric Dryer
No power
make sure the power cord is plugged into a working outlet, and make sure the other end of the power cord is firmly seated in the power supply. also look at the side of the plug, there should be a slide switch label (112V, 240V), make sure the slide switch display 112V. (if you are in USA). otherwise 240V.
if this help you solved the problem. please rate the answer.
thank you
Oct 15, 2008 | E-Machines Computers & Internet
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool LEN2000PW Dryer Logo
251 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
