Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Forgotten seagate freeagent pro encryption password
I have forgotten the encryption password evidently and short of spending years trying to remember it I was wondering if there was an easier way. Possibly a way to crack it? the model num is st305004fpa1e3-rk p/n is 9ng7a6-570 help me please!
  • 728 Answers
Hi dollarbilll,
You can ask for your password hint to help you remember your password, as long as you
originally created a password hint.
If you still can't remember your password, the only way to regain access to your Seagate
Secure drive is to KeyErase it. This will erase ALL of your files and allow you to reset your
password.
Once you KeyErase your Seagate Secure drive, there is no way to recover your files (even by
using a data recovery service). Only do this as a last resort!
The one other thing you may try is to copy the folder if you can get to it, someplace else on another drive and go to properties and see if you can change the ownership of the folder and gain access.
Otherwise, keep trying to remember.
Mark
Posted on Feb 23, 2009
I have forgotten password for encrypted memorex travel drive
you can send it off to one of those companies that specialise in data recovery if not all you can do is reformat :(
That is why they are secure ..... sorry :(
Jan 17, 2015 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
I have a Seagate FreeAgent Go, 500 GB, sn2GE6NC5Z. My computer crashed and took it in for repair with the seagate. In fixing the computer, the service person erased everything on the seagate drive. Is...
FreeAgent™ Software Version 2.1.600 includes folder encryption. This download is compatible with all versions of 32- and 64-bit Windows. This software may be used in conjunction with FreeAgent DockStar™.
FreeAgent? ' Go Software Download for the FreeAgent? ' Go in case the software has been deleted from the drive
FreeAgent? ' Desk Software Download for the FreeAgent? ' Desk in case the software has been deleted from the drive.
FreeAgent? ' XTreme Software Download for the FreeAgent? ' XTreme in case the software has been deleted from the drive
hope this helps you
Jul 25, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My Seagate FreeAgent Pro HD won't turn on anymore. Any suggestions?
If it's not turning on at all anymore and it's plugged in properly, there isn't much you can do. Everything I've purchased from SeaGate wasn't meant to last. In other words, after a year or so, they quit working. It's probably some kind of marketing scheme to get you to spend more money. Open up the case, take out the drive and stick it in your computer. That way you can still salvage what's left on it.
Dec 26, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Multisystem ulility plus supporting OS
If you use the utility that comes with the drive, you will be able to access all of your files and folders that you encrypt on the drive privided that you don't forget your password. If you want to make sure that the drive is protable (can be used on multiple systems), you need to make sure you enable Travel Mode with the Seagate Manager software. You must remember the password in order to access your files.
Jul 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
May 27, 2009 | Seagate FreeAgent Pro 500GB External USB...
Seagate Free Agent 1.5TB doesn't encrypt
I was fumbling around with this as well. I found a manual on my external drive itself. I had to read through it carefully before i saw a small note.
Note: After you open your Encryption folder on the first computer and user account with which
you use Seagate Manager, it will be saved on that computer so that will never need to
enter it again. When opening your Encryption folder from another computer or user
account, however, you will need to enter your password.
I have yet to test it by creating another user account, then attempting to access the files. I am confident that this is the answer.
Mar 01, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Free agent doesnt encrypt
I Posted a solution to this prob but i don't see it anymore. Your ext drive is Encrypting your folder. It just knows you're the one using it. If I took it and plugged it in to my computer, it would recognize my user name as t0mthab0mb and prompt me for the password. Try it. Create a different user account on your computer, then try to access the encryption folder from the new account.
Forgot Encryption Password
Visit seagate website else format in dos prompt
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dead Freeagent 500GB Drive...
I don't know which drives they use in Freeagent, or even how you open the case (don't remember seeing any screws on mine), but Seagate drives (baraccuda especially) are known to have a weakness with the diode between 12V and Ground.
If it seems like it's shorting, (put a meter across the power input before you bother opening it - if it's reading about 1 Ohm, this may be your issue) might be worth opening the case and checking for a small square surface-mount diode marked BUX C??? (? being a variable number). If it's shorted, then clip it out for a quick-and-dirty backup of your data & bin the drive, or fix with a suitable replacement diode (SMD 1N4004 has been suggested).
Aug 21, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lost network password which I need to sign on an ipod touch using a netgear dg834gt
Key 1 should work in most cases. If you have additional keys listed, try them also.
If none work, turn off encryption and connect your new device, then create a new password.
The manual page is here:
http://kbserver.netgear.com/kb_web_files/n101675.asp
Nov 19, 2007 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,541 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
