Question about Promise Supertrak SX6000 (p29sts600000000) ATA Controller
Windows 2000 Professional will not format SuperTrak SX6000 array.
I got a strange somewhat old computer that it has a SuperTrak SX6000 card on it. I installed Windows 2000 Professional on it and everytime I try to format the "drive" corresponding to SuperTrak array, it does not complete successfully (it takes its sweet time). I tried everything. The drivers are installed, they show in the Device Manager. The drive shows with the capacity of the array but it can not be used unformatted and no formatting will succeed. I even installed the PAM utility in Windows and used it to recreate the array but, again, when I tried to format it, did not succeed.
I tried changing the OS in the card BIOS to no avail. I may be missing something basic here because I don't seem to find a way around it.
Any help will be appreciated.
Update the BIOS of the card and the firmware... It might be bug!!!
Posted on Apr 01, 2009
8GB micro sd card formated for 34MB how will i format for 8GB
Step 1:
Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 Click start click on my computer you should see your USB Drive right click then select format another way is to control panel administrative tools computer management disk management right click on your USB Drive select format
Mar 14, 2013 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I cannot install windows 7,no disk seen are there drivers for raid smart array 5I for windows 7? DL 740 G1 , 8 x 2700Mhz+40GB ram , 4 x 73gb Raid 5
Not quite sure what your problem is but I would recommend getting Windows Server for a server like this. The HP site recommends the following OSes: Microsoft Windows 2000,
Microsoft Windows Server 2003 (Standard, Enterprise, and Datacenter) ,
LINUX (Red Hat, SuSE) or Microsoft Windows 2000 Datacenter Edition. It is unlikely Windows 7 will install on this 5 year old server.
Jun 06, 2011 | HP Compaq ProLiant DL740 Server
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I need to reload Windows 2000 Pro on a corupt IBM Thinkpad.
Assuming you have no data to lose,,,, you could always try to download copy of Windows 2000 Professional and burn it to a CD. Before you do this,,, you have to make sure you have a sticker somwhere on your laptop with your original product key. If you do decide to download Windows 2000 Professional,,, make sure its an OEM copy,,, and of course there is no guarantee that it will be a full copy, or a copy without virus's in it. DO NOT try to download Windows 2000 Professional if you dont have the original product key, as it is illegal. Also,,, do not try and find a product key online,,, that is also illegal. I have to be perfectly clear that the only legal way to download somethign like Windows 2000 Professional is if u have the original product code or key. You can than use this newly burned copy to format and reinstall windows, and than from IBM's web site u can download all the drivers needed for your model
Mar 13, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
A friend gave me an older computer /w Windows 2000 Professional
Sir,
Better to format the drive and reinstall the OS(Operating System)
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 11, 2009 | Microsoft Windows 2000 Professional for PC
Cannot open windows corrupt file. Cannot even
Try a repair in the install disc..(or format pc) using a formatting diskette. preferable
Feb 27, 2009 | Microsoft Windows 2000 Professional for PC
Operating system
You can not upgrade to Windows 2000 server from windows XP Professional. All you can do is to purachase a copy of Windows 2000 server with as much as client license you want. And install it in your system on a sperate partition. Or you can install windows 2000 server after formatting your hard disk. This way you will loose any information on your computer. Installation instructions are available on the internet in the following link: http://www.petri.co.il/install_windows_2000.htm If you are using a simple stand alone machine, your current windows XP professional is the best choice according to my knowledge. All the best
Sep 27, 2007 | Delfield DEL-F5MC48N-CLO-0 Mirrored Backed...
Promise Supertrak SX6000 (p29sts600000000) ATA Controller Logo
106 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
