Question about Acer Aspire 6920 Notebook PC
Unlock volume console
Bult in console, on keyboard, with finger-touch control is locked on "off"
  • cockroach57 Mar 18, 2009
    the pad is turned on tho it won't react to touch, the lights still work but i am not sure if the touch sensor is screwed or what, help anyone
  • milolaine Apr 05, 2009
    yes, the volume light is at maximum but the speker mute light is also on and it wont react to any of my touches. good thing i can still use the volume control at the taskbar. however the left side controls are frozen. it was working then one day it just wont budge.
    Problem Solver:
  • 5 Answers
I had this issue too, there's a couple of threads on this site - seems to be a common issue.
Turn of your machine (and remove from charger if this is the case), remove battery & wait for a little over 10 seconds... then replace the battery and boot as normal.
This seemed to rectify the problem with my machine, but some people weren't as fortunate. Hope all goes well for you!
Posted on Aug 17, 2009
My sister locked his tablet with a password and now he cant remember what the unlock code is. its the type of code you unlock by making a pattern with your finger.
You have to reset it to factory default just follow those steps:
1. shutdown the tablette
2. hold volume up button and press the power button
3. when manufacturer logo come realise the power button but keep hloding the volume button to get into recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind the all data in the phone will be erased (apps & games)
ALL DONE!!!!
Mar 05, 2015 | Proscan 7-Inch Android Internet Tablet,...
ALL DONE!!!!
I have a new galaxy S5 and i set it up with fingerprint to unlock but it keeps going reverting to password to unlock, how do i get it to stay on fingerprint?
Here is another way to unlock pattern lock for Samsung Galaxy phones, also works with password, fingerprint and PIN. Moreover, no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Oct 06, 2014 | Cell Phones
How do you unlock the keyboard
Is it that the keyboard is locked so no keys work, or is the touchpad locked so that the mouse pointer does not move?
I've seen more and more people locking the mouse pointer. If that's the case there might be a button to push that is at the top of the touchpad in the middle that toggles it on and off. Also on some brands, you will have to hit either the FN or ALT key and hold it down while you hit the F1 thru F12 key that controls the touchpad. Usually the correct key to press will have the icon of a finger in a square box representing the touch pad.
Apr 03, 2012 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Computer compaq nc 6000 power off during working
If you feel the power adapter working fine with the diff unit its not an issue with the adapter,
Now, if the unit is not powering on.just perform this:
Take out the batter, adapter and make the unit stand alone and press and hold the Power button with out any power to the unit(Without battery , adapter) by doing that we can take the static charge which might be causing the issue,
If that does not fix the issue, try reseating the RM if you are comfortable, here is the steps:
Primary memory board removal Before you begin: Remove the battery and keyboard.
  1. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    Caution! When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  2. Grasp the primary memory board by the edges and pull gently to remove it.
  3. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
Steps to remove Keyboard:
eyboard removal Before you begin: Remove the battery.
  1. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  3. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
  4. Turn the notebook right side up and open the display panel fully.
  5. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  7. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. After ensuring that the locking bar on the keyboard ZIF connector is unlocked, place the keyboard right side up on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Toe the tabs on the bottom edge of the keyboard into the top cover.
  5. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  6. Close the display panel and turn the notebook upside down.
  7. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
  8. Toe the memory/Mini PCI cover into the enclosure.
  9. Tighten the captive P1 Phillips-head screw.
Jul 06, 2009 | HP Compaq nc6000 Notebook
Hi, Try doing the following:
1. Turn of your laptop 2. Remove the battery and the power cable for about 15 seconds 3. Reinsert the battery and the power cable 4. Turn on your laptop.
Your Cinedash Console should be fully functional again
Good luck. Cheryl
May 28, 2009 | Acer Aspire 6920 Notebook PC
How to disable side volume key
1. In Idle mode, enter an
area code and phone
Press [ / ] to adjust the
volume.
During a call, the
exposed keys are locked.
Press [Centre] to unlock
the keypad.
To change the sound profile:
1. In Idle mode, press
[Centre] and select
Settings → Phone
profiles.
2. Select the profile you
Jan 25, 2009 | Samsung SGH-U700 Cellular Phone
Toolbar
Go to control panel> sound speech....>sound and aud...> uncheck mute.
to activate the soft keys on ur keyboard, install the keyboard drives which came with the the computer.
Hope it will help :)
May 25, 2008 | HP Audio Players & Recorders
Acer Aspire 6920 Notebook PC Logo
353 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
