Question about RCA L42FHD37 42 in. LCD HDTV
Have our computer hooked up to tv to use it as a monitor
We are not getting any signal
it says on the tv screen unusal signal
  • Anonymous May 16, 2009
    Same thing unusable signal but what are the settings?
  • 416 Answers
Check/adjust the resolution for second monitor (the TV) and frequency. In Vista/XP you must get upon clicking on display properties.
Let me know if you need more info
Good Luck
Posted on Feb 23, 2009
Element tv problems hook to computer get no signal
I'm assuming you are using this as an only monitor for the PC...
What resolution is the screen (max) and what are you trying to put into it? If the video output of the PC is too much it won't 'see' it sometimes... try lowering the PC resolution to that of the screen.
If it's a second monitor, you have to go into the screen settings on the PC and tell it to either 'mirror' (or duplicate) the existing monitor on it or extend the screen on another monitor.
Sorry I can't be more specific as I don't know what the screen or PC (computer) is...
Apr 23, 2014 | Element Electronics Televison & Video
Look at the function keys (F1 to F12) in your computer since there is a shortcut key in it. Look for a key with an icon resembling like a TV and a PC Screen with a slash. It's like TV/Monitor icon.
Now with the PC (laptop?) hooked with the TV, (the tv showing no signal), hold down the FN key and press that function key with the TV/Monitor icon.
Jun 04, 2010 | Computers & Internet
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Trying to hook my sanyo 32in up as a monitor for my computer running on windows xp when I hook it up it gets sound and acknowledges the cord is connected(the no signal sign goes away) but the screen just...
Your computer may be sending out a video signal that's too high of a resolution for your TV to display. Try reducing the resolution of the computer video signal.
May 13, 2009 | Sanyo DP32648 32 in. LCD TV
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
Can i hook up a ps3 without attaching the cable? My son wants to use the tv mainly to play video games and later as a PC monitor. Do I really have to run another cable through the house just to get a...
No you dont need cable the game consoles can hook right to the t.v. Try hitting t.v video and seeing if its on another video channel. also make sure all of the rca jacks are hooked into the in on the t.v
Mar 11, 2009 | RCA L22HD31 22 in. LCD HDTV
Can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Jul 23, 2008 | SVA-USA SVA HD4208TIIIBU 42" Plasma...
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
RCA L42FHD37 42 in. LCD HDTV Logo
234 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
