Question about Sony Computers & Internet
I turn on my laptop see the all light on and with in a minute the hd light turn off but never the screen go on it there a key to make this computer to boot up thanks
  • Felinna
    Felinna May 11, 2010
    is there a problem with the screen?
    does the computer stay on with the screen dead, or does it shut down along with the hdd?
  • Vincent Martins
    Vincent Martins May 11, 2010
    What's the brand and model of the laptop?
    President:
  • 1,223 Answers
It is RAM issue try changing RAM and let me know
Posted on Feb 23, 2009
Very dim screen image, have to see using flashlight ?
Have you tried holding the "fn" key and the F key that has an arrow up or light symbol on it?
Nov 17, 2014 | Compaq Presario CQ56-204LA Laptop Screen...
Computer will not start
take the battery out, let it sit for 1 minute. then plug it into AC. Does it start?
Jun 20, 2012 | Dell Vostro 1500 Notebook
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
I had a problem with firefox on my acer one, decided to use rescue disk to reinstall, now all I get is a black screen! The computer starts, no bios screen comes up, but lights flash, external dvd drive...
Your best bet is to take out the hard drive, plug it in to another computer, back it up, and then reinstall with the original disc, then put everything back on.
Mar 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
When turned on the computer stays at a white screen. It shows an icon that it is processing but it never goes off that screen. This happened after the computer froze and then shut off.
When you first turn the machine on, hold down the "Option" key. Then select Macintosh HD and click the arrow below. If this doesn't work then try another key combination: Option, Command, P, R. Hold this down until the machine restarts itself. This will reset your machine's PRAM which can help.
Feb 07, 2011 | Apple MacBook Air
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
I have Aspire 5520-5912 Notebook. When I turn on power with battery or ac adaptor, the power just comes and goes, the power button light, power indication light and HD operating indication lights just...
I m also suffering from same problem on aspire 4310. When the problem occurs, I remove the battery for an minute and insert again.... This trick have solved my problem. Try the same trick on your laptop and see that whether it works or not... Otherwise get it serviced....
Thanks...
Jun 30, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
Hard Drive doesn't show up
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Computers & Internet Logo
21 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
