Question about Heavy Machinery
38182 toro snowthrower will not start because i think i did not add oil to gas & ran engine for a while. what did i do? how do i fix? tried to start with holding in electric start button for several minutes. engine turned over but sounded horrible. i know i probably really messed up. please help.
  • popee8 Feb 23, 2009
    Wow! Cannot believe that just a little oil would have such dire consequences. How much $ are we talkin about? for repair? for new? Was just cleaning brothers drive while he was gone out of town. Just trying to help him out & do him a favor. No good deed goes unpunished. What do i do to make things right? Will have fixed but what will it cost? Thank you.
  • adamnorris Mar 11, 2009
    I recently ran my two-cycle Toro Powerlite with straight gas for a tank since I had no oil on hand. Once it ran out of gas, the engine wouldn't restart. When I brought to the dealer, he said that in this type of engine, without oil, it wears out the "rings" around the piston. Therefore since the seal is now worn down, I have no compression in the gas engine, so it won't run again. They do not fix or rebuild on two-cycle engines so he pointed out it's a paperweight now. Same mistake, whod'a know. Oops. I'll make sure to have gas for my snowblower, weed wacker and hedge clippers going forward. Wow.
I USED TO WORK AT A HARDWARE STORE AND A LOT OF PEOPLE ALWAYS HAD TROUBLE WITH 2 CYCLE ANYTHINGS(GAS & OIL MIX).IF IT IS AN ELECTRIC START MAKE A FRESH MIX OF GAS AND OIL TO SPECS BUT USE A LITTLE MORE OIL THAN INSTRUCTED(THIS WILL NOT HURT THE ENGINE).ADD THE GAS AND OIL MIX TO TANK. PUT CHOKE TO FULL, PRIME IT 5 OR 6 TIMES PLUG IN THE ELECTRIC START AND PRESS THE BUTTON AND HOLD IT DOWN 'TIL YOU HEAR THE ENGINE START TO REVOLVE.THIS MAKE TAKE A FEW TIMES BUT IT WORKED FOR ME.YOU HAVE NOTHING TO LOSE BEING THAT THE ENGINE MAYBE SEIZED ANYWAY. GOOD LUCK !!
Posted on Dec 28, 2010
Toro 621 back firing
if oil/gas mix is run thru a four cycle engine , id suspect the plug is fouled with oil , this may require replacement once your sure all the oil is out of machine completly
Feb 25, 2015 | Toro Power Clear 621 R
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here - http://www.partstree.com/parts/?lc=toro_consumer&mn=38182%2C+Powerlite+Snowthrower%2C+2009+%28SN+290000001-290999999%29&dn=3358-429-383366-0008
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - http://www.partstree.com/parts/?lc=Toro+Consumer&mn=38182 and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
I am looking for the owner's manual for a Toro snowthrower CCR Powerlite 325E 38182
I think if you write the company and tell them your problem they will send you one. I wasn't able to find it either.
Good Luck,
Jim
http://www.toro.com/intl/ca_en/home/snowthrowers/gassinglestage/ccr325.html
Sep 09, 2010 | Garden
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Engine will not stay running
Hi
When the engine stops check the spark at the spark plug.Check compression(remove the spark plug and ground the plug wire on the engine,seal the plug hole with your thumb.Operate the starter.If the compression preasure blows your thumb off the hole,the compression is adequate for the engine to run.Now priming the engine(put some gas into the spark plug hole,back the spark plug and try to start the engine.Let me know. savumihai71 regards
Dec 10, 2008 | Toro Garden
Heavy Machinery Logo
845 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
