Question about Logitech X-230 Computer Speakers
My x230 wont work it work for a min then cut out and dont work!!!
It just stopped and i opened it up and it work for a sec then now it dont work please help thanks
  • 3,267 Answers
Try and twist the jack which is connected to your PC, the solder inside could have snapped. If it has a diferent pwer source for the sound system, then power on, hold the jack and short the ends with your fingertips. If the speakers dont respond then its not getting any power, which could be simple loose connection too. Test both and then decide. If you dont have the correct driver then download from: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q........sodeep
Posted on Mar 22, 2009
Trackpad keeps freezing when lan cable is plugged in
I would recommend installing all the newest drivers for the unit.
Feb 15, 2018 | Lenovo Thinkpad X230 Laptop Notebook I5...
HOW TO BYPASS THE ANTI THEFT SYSTEM IN A CHEVY CAVALIER
Does your system have a resistor pellet in the key?
Apr 09, 2013 | 1999 Chevrolet Cavalier
Car want stop ideling
check the check engine light my dodge was doing that 2 sum bout the cooling system dont knw 2 much bout cars but it dont do it knw just when i drive it bout 45 mins and cut it off it wont started back up for about 45 min
Jan 13, 2013 | 1999 Dodge Intrepid
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
My remotes will not activate the opener from anywhere but inside the garage. Worked fine the first month then stopped
2 possible solutions; #1) unplug the motor for 3 mins then replug (resets memory) #2) on back of motor is a "learn button" - press learn button for 3 sec, then press your remotes for 3 sec.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Emachine W5243 keeps cutting off (stays on from 5 mins to 20) just cuts off, thats it.
chack your prosser cooling fan is not working that y your cuts off
open your case then star your CPU and keep waching your Prosser FAN you will see after some time it will stop or it wont start at all
May 04, 2010 | E-Machines eMachines Desktop PC
Pump runs for about 15 secs then cuts off.
try testing the starting capacitor by first disconnecting the power, opening the cover on the end of the motor, and test the resistance of the capacitor
Jan 24, 2010 | AO Smith SQ1152 Pool Pump Motor
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
Sep 28, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Logitech X-230 Computer Speakers Logo
231 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
