Monitor light will not turn green from yellow
Foxcon motherboard a7vmx after installation will not work with monitor
  • 530 Answers
Hi im josh in cebu phils.friend if your pc wont display after the installation. the problem is centered on your video hardware. try to install the driver of your video hardware.or go to the bios setup menu then system performance down agp aperture increase the number if your using agp video cards it will help you. good luck
Posted on Feb 23, 2009
Long continuous loud beeping sound coming from the foxconn a7vmx-s motherboard. Please help
These are called Beep Codes. The kind of beep indicates that the motherboard cannot post, and gives you some idea of what is wrong. These codes should be located in the booklet that came with your motherboard or the computer. You can also try the computer manufacturers website, hopefully they posted a manual for your computer.
Sep 19, 2013 | Foxconn A7VMX-S Am2 Ddr2 Motherboard
My monitor turns on with a green light and then immediately changes to a yellow light
Sounds like you have no video output from the motherboard. Unplug your desktop computer from the wall so no power is going thru it. Take out all the memory sticks from the slots. Then go ahead and reseat one of them in any slot. Then with the Monitor hooked up turn on the computer. If you still don't get video then repeat the steps and try the memory in each other slot.
If you have more then one memory stick try each one in each slot. If you still have no video after trying all the slots with each different memory stick then that means the motherboard is bad.
If you have a external video card that was installed then take that out and use the internal one that your motherboard came with and swap out the memory using that.
Basically your turning off the computer swapping memory out in each slot and turning the computer back on to see if you get video to come back on.
Feb 05, 2012 | IBM Aptiva E 500 (2158500) PC Desktop
My advent pc which has a fox conn a7vmx k motherboard wont boot up, it powers on with constant fan only. I've removed and put back in each device one at a time but that failed too. Anyone know what I can...
Keep connected just the keyboard, mouse and monitor and try to boot in the BIOS - if it fails then the motherboard is faulty and you must replace it.
Dec 05, 2010 | Foxconn A7VMX-K Motherboard
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
Tower turns on monitor shows no signal
I am guessing what you mean is that the monitor won't turn on. Does it have a green light or a yellow light that turns on?
If it is plugged in, there should be a light. If not, the monitor is bad. If the light is on but there is no video, then your video card has gone bad.
Jan 24, 2009 | MSI KT4A Ultra (MS-6590-050) Motherboard
Pc won't boot up
If the Monitor Lights change from GREEN to YELLOW then it cannot detect a signal from the Video Card. If you have a different monitor, hook it up and see if it makes a difference.
If it does get another monitor...
If it does not make a difference. Open the computer and see if the monitor cable plugs into the Motherboard directly or into a video card.
Which ever way it is try adding another video card.
You need to check what kind of video card you need, AGP, EPCI, etc...
If it has a video card in one of the slots, remove it, try another one in the same slot.
If it plugs directly into the Motherboard add a video card to the slot nearest the power supply.
*NOTE: any video card you try to install will work with your monitor without drivers,
If you install the card and turn it on you will see stuff on the screen without installing drivers.
When you install an operating system, ie: Windows, Linux, Unix, etc., then you will need
to Install drivers.
Nov 22, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
