Question about Kenmore 22422 Top Load Washer
Top load Kenmore 800 washer will not fill with water
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual - any idaes what happened to it?
  • Jeff MacDougall Mar 02, 2009
    I have had mine almost 3 weeks and now only spin works. No wash or rinse!! I just got rid of my 11 year old kenmore series 90 washer for this one. The transmission went on it. I must have put $300-$400 in parts from repairclinic into that one before it finally died. Anyway, my 800 washer is dead. I fell for the sears 3 year extended protection so they are on it. I just hate waiting!!!!! I almost was going to send it right back which they would have but gonna try 1 shot to have them fix it.
  • Anonymous May 08, 2009
    Same thing. No wash or rinse, only spin. 4-1/2 months old.
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
  • millerdax Jan 13, 2012
    Ours won't fill with water either. Had a repair man with 30 years experience at our home for over an hour. He checked all the switches, circuit boards, hoses...everything works. It just wil not release the water. He told us it was live someone sabotaged it just to see if he could figure it out. He told us that he would have to go and research this further. After waiting a couple days of waiting for him to get back with us we found a great for a new one. In the meantime we still have a washer that doesn't work and don't know why. The good thing is that the repair man didn't charge since he couldn't fix it.
  • Kenmore Master
  • 1,230 Answers
Hoses sometimes have a screen to prevent trash from getting into the water valve. Turn water off, disconnect hoses and check for clogging. If it is a used unit, the valve may have "Given up the ghost". Not real hard to swap out. Check with local appliance store for parts. Don't over look a loose wire. During shipment, driver's never hit potholes. Ya, right. Worst case, the time has quit making contact to the water valve. They can be replace too but alittle more of a headache. Good Luck
Posted on Feb 23, 2009
Sears is having a lot of problems with a switch on this model that controls the water level. We bought one, had problems, returned the washer, got another one, and the newer one gave problems. Called Sears who sent out a technician who replaced the switch and now the washer works fine. How long will it work, no one knows.
Posted on Aug 14, 2009
We have a Kenmore 800 washer, model 110-28832700. It washes and when it gets to the spin cycle....nothing...just stops....We have to turn it off...let it just sit for a while, then turn it back on...and it will start again. It's less than 2 yrs old, we have had Sears here several times, last time they replaced the timer....helped for a while now its doing it again. Any advise what it could be this time....its out of warranty, even the new timer, so the cranky rep at the Sears Service Line told me...I made a appt for them to come out again....but her being as rude as she was...Sears never showed for the appt...Any advise would really be appreciated...
Posted on Nov 28, 2009
Hot water cycle don"t work
Posted on Jul 06, 2009
3 Suggested Answers
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
8 out of 10 times the hose screens are clogged.  1. Remove the hoses from the back of the machine, but leave them connected to the hose bibs.  2. Remove the screen from the hose (it may be stuck at the back of the machine) (This is where deposits usually build up.) 3. Aim the hoses into the drum or a bucket and turn on the bibs. 4. If you don't have a full flow of water coming out of the hoses you will need to remove the hoses from the bibs and reverse the process. Good Luck.
Posted on Apr 30, 2009
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
1.- replace timer
2.- or motor has thermal fuse check continuity.
3.- replace lid switch
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
Mar 13, 2009 | Washing Machines
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore 22422 Top Load Washer Logo
6,528 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
