Question about Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I would like to know where i can find an on and off switch for a hobart stand up mixed model number a200.
  • Anonymous Feb 24, 2009
    regarding the model number of the stand up mixer it is a-200
  • ritaindurant Feb 25, 2009
    Hi its me again about the hobart stand up mixer model # a-200, serial# 977744,and the spec# is 3943. speed 172.5 and the hp is 1/8 voltage 115 and the amp is 5.56. and again i am looking for the on off switch and wiring diagram.
  • 640 Answers
I'm a hobart tech---what is the ml number on the data plate?
Posted on Feb 24, 2009
  • anthony james
    anthony james Feb 25, 2009
    Not the model number,If you look where the data plate on the back of the mixer there will be the serial #,model #,ml or spec #.
How to invert motor turning direction?
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
Very old a200 ml#....?
Go to this site it is the parts list for the A200 and the A200T
http://hobart.co.kr/manual_pdf//013.pdf
Then go here for parts and parts number confirmation
http://www.food-equipment.com/parts_Hobart_mixers.htm
Hope this helps if so let us know.
Sep 20, 2012 | Hobart A200 Stand Mixer
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Jan 04, 2011 | Hobart A200 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Hi, I have a Hobart A200 F model mixer. The rear of the motor housing has a crack in it, just about where the rear bearing is. Can this type of metal be welded? thank you.
I'm a hobart tech and repair these often.I suggest you use jb weld,its a 2 part mix and is very strong if you follow the directions carefully.I would not weld,been there done that with no luck.Any ?
May 16, 2009 | Hobart A200 Stand Mixer
A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Feb 09, 2009 | Hobart A200 Stand Mixer
Hobart A200 MIXER ON/OFF SWITCH
I would call hobart and have all the information about your machine you can find on the data plate they have more that one style of switch
Jan 28, 2009 | Hobart HL600 Legacy Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
262 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
