Question about Frigidaire GLTF1670A Front Load Washer
Frig front load washer GLTR1670AS too much play in tub
Washer was in final spin mode,almost done, and made loud noise like something was caught inside somewhere,will still tumble and spin out,but there is way too much play in tub, when door is open the tub can move back and forth almost like a swing does.......what is the problem?
  • 188 Answers
Remove the kickplate and inspect the 2 tub shock absorbers, it sounds like they might be broken. If the tub is hanging to one side or dropped all together, remove the top and check the tub support springs.
Posted on Feb 23, 2009
Rumble on spin
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Feb 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Noise as is spins
Feb 24, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
During spin cycle loud clunking noise
Feb 16, 2014 | Frigidaire GLTF1670A Front Load Washer
Spinning cycle sounds rough
Feb 12, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer motor makes lots of noise as its trying to spin. Hardly spins at all with wet load. Spins slowly and still makes noise when spinning with drum empty. Does this mean the motor is bad or is it the...
If it is a really loud noise that drives you out of the house then probably a bad bearing. If that is the case then time for a new machine. Also check for something caught between the tubs.
Dec 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
In the final spin the washer is so loud you can't stand by it what is wrong with it
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Grinding Noise
yes you are right the tub bearing has failed
May 21, 2009 | Estate TAWX700JQ Top Load Washer
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Maytag MAV7600 - loud noise on spin cycle
It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Dec 26, 2007 | Maytag MAV7600 Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
