Question about Maytag Washing Machines
Maytag LSG1000 - water pouring out of injector sleeve
I have a Maytag LSG 1000 and water when filling is pouring out of the injector sleeve bracket and onto the floor. What is the problem and how can we fix it?
5 Suggested Answers
SOURCE: Maytag atlantis washing machine
It will not spin out all of the water out of clothes, spins VERY slow
Posted on Dec 10, 2007
SOURCE: cabrio drains water onto floor.
I took the back cover off of the machine and found that the drain pump had a hole in it. The hole was caused by a coin that had made it's way down to the drain pump. The replacement pump cost $90.00 and was very easy to put in. If you google the words cabrio tear down you will come across a web site that has a video that shows you how to take the pump out. I have not had any leaks since. Keep the coins out of the washer, remeber to check your pockets to avoid paying out cash.
Posted on Jun 12, 2009
  • 112 Answers
SOURCE: Tricity Bendix AW1400W front load. Water leaks
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Posted on Aug 17, 2009
  • 464 Answers
SOURCE: Water leaks out the top of the Injector Sleeve
if this part is about 2 1/2" long and black rubber and has a white plastic tube inside it, yes it is necessary and do not take it out. the rubber is probably getting thin and causing the leak. they are not expensive parts and should be replaced. can do yourself.
Posted on Nov 13, 2009
SOURCE: Maytag washer filled with water then stopped working.
You can check the lid switches (they are paired) the following way:
1) take off the front and top washer housing panels.
2) look for the wire bundle coming off the lid switch and find the plastic pull apart connector.
3) undo the connector.
4) take an Ohm meter and check the resistance when the lid is closed: a) orange and black wires should complete a circuit, orange and pink should also complete a cicruit, all other pairs shold be "open".
5) check the resistance when the lid is open: orange and white should make a circuit, but no other pairs.
6) replace the defective switch, or replace the complete unit.
7) check the 250V 1A fuse in the left front, replace it if it has blown.
Good luck.
Posted on Dec 15, 2009
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Water leaks out the top of the Injector Sleeve Bracket, which does not have a cover. Is this part necessary? Can the 2 water tubes be joined by a standard water tight connector?
Nov 12, 2009 | Maytag Washing Machines
Water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Sep 29, 2009 | Washing Machines
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Water Leak Top Load Maytag Washing Machine
you have a leaking "injector sleeve". you need to remove the 2 screws that hold on the front panel ( they are at the bottom) once you remove them, pull the panel outwards, towards your knees. it will release. on both sides in the top you have 2 bolts, remove them, it think they are 3/8ths. on the left if you have a bleach dispenser, remove that hose before you lift the lid. Once the lid is up you will see the injector area on the top left at the side. Hope that helps
Mar 02, 2009 | Washing Machines
Maytag washer pours water out bottom instead of filling up
Check the water pump for physical damage from the move. If the washer was laid on it's side, you may have either snapped off the pump outlet or broke the pump body. You may have broekn the body of the water inlet valve fill flume. A visual examination should provide a lot of insight as to what the problem is.
Dec 20, 2008 | Maytag Washing Machines
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
134 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
