Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Compressor runs for 5sec.
Compressor runs for about 5 sec. Fridge is not keeping anything cold and Freezer is not keeping anything frozen.
  • 410 Answers
The sound your hearing is most likely the starter relay for your compressor. this is a common failure part for this model whirlpool. if the unit is out of warranty you can purchase part# 8201786 from any local appliance parts deealer, online at numerous parts suppliers or the easiest in my opinion sears partsdirect.com. the kit is a plug and play part and has very good instructions so that you could replace it yourself. the part should be less than 65-70 dollars.
I do reccomend that you unplug the refrig to prevent damage to your compressor.
If you have any further questions please leave a comment here and I'll be glad to assist you in any way I can. thanks Peyton
Posted on Feb 23, 2009
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Nov 17, 2011 | GE Refrigerators
The fridge & freezer has started to get warm it was 8deg above the recomended temperature & then the light starts to flash,we have cleaned all around it,taken food away from the outlets in the...
it can be a defective thermistor,a defective cold control or compressors short cycling(not running long enough) or the evaporatorin the freezer is frozen up and cant keep temps constant
Aug 03, 2011 | Refrigerators
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
136 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
