Question about Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Slow Printing
I've been using the 1600n MFP with dual trays, 160mg ram, pcl6 driver, connected via ethernet cable as my main printer. Everything (scan, fax, print, copy) works, however the printing of PDF files is painfully slow. It's not a problem when I have 10 or so pages, lately I've been printing sets of 100+ pages. I've changed settings for spooling options with no noticable difference. I also have an HP 2200dn in my car that I can literally bring inside, hook up, print a set, and put back in my car and still have time while the 1600n is printing the same set. (It was in my car for business reasons; and now is my primary printer)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Posted on May 09, 2009
I am using hp 3505 color lesser printer on windows 7 32bit, Driver that was installed automatically by windows is "HP Color LaserJet CP3505 PCL6" My tray 1 that is multipurpose tray is printing slo
Make sure that you have tray 1 set for the correct paper type. Leaving the paper type as unknown will result in very slow printing as the printer will assume that it might be printing on heavy media, envelopes or the like.
Feb 02, 2015 | HP Office Equipment & Supplies
Connect dell 1600n to computer
This model Dell printer can connect to your computer by -
Hi-Speed USB cable, or
a LAN cable over your network using Ethernet 10 Base-T/100 Base-TX
May 18, 2012 | Dell 1600n All-In-One Laser Printer
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n. I have to reset the printer constantly.
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Sep 12, 2017 | Dell 1600n All-In-One Laser Printer
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Our Dell 3100CN pcl6 still prints, but it makes a grinding noise.
I had the same problem, tried to use the MFP tray, got jam, couldnt't close the rear door and used appropriate force... terrible noise with every print thereafter.
I fiddled with the roller at the back of the MFP tray. It didn't want to move much but after rotating it ~ 45 degrees back and forth it was in a more loose position. That seems to have solved it, no more noise!
Jan 22, 2009 | Dell 3100cn Laser Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
259 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
