Question about GPS
Frozen map screen
The map screen froze and will not reset itself. Other functions use such as I can enter address or delete address but it will always give directions from the frozen location.
Try purchasing a new SD memory card (brand name) and installing the files there. Sometimes the manufacture sends cheap SD cards and the data is easily lost in damaged or poorly made SD cards. I have a EVESHAM 2007 and installed the files from the original CDto a new SD card and solved freezing and other problems resulting from poor data transmission from the cheap SD.
Also, try going online to the manufactureer's web site to see if they have downloads/ updates available there to replace the origianl install files that came with the unit. Always put on new brand new SD card.
Hope this helps
Posted on Feb 24, 2009
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
Screen froze jaguar xf
same here ! solution??? screen has the ENTER PIN FOR BLUETOOTH frozen and floating over the usual touch
screen/icons
Nov 18, 2012 | 2011 Jaguar XF
Frozen. Yellow light on, Buttons appear to do nothing.
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
May 26, 2009 | Symbol P470-SR1211100FB Handheld
Keeps saying no map data available
try going to garmin site and download a files for it
Jan 29, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen on ''aquiring satelite''
Try resetting the I5. Hold the left button, the wheel button and the power button down at the same time. Keep holding until the screen say that " Do you really want to erase all user data?" Select Yes and then restart the I5.
Nov 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Help frozen up zen vplus 4gb
I had the same repeating problem with my Zen V Plus 2GB. There is a tiny hole on the left side of the player, underneath the on/off switch. Stick a paperclip in there and press gently to reset your player. I lived for 6 months letting the battery wear itself out before I discovered this reset hole. I finally found the offending piece of music and deleted it from the player. I haven't had any problems with my Zen freezing since deleting that song. Pay attention to whether it always freezes on the same media, that might be the source of your problem.
Hope this helps!
Jun 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
Streetpilot c330 Frozen on.
take the face plate off of it, and to the right of the screen there is a reset button
May 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen hard drive
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Feb 15, 2008 | Thomson DPL909VD System
Audio turn by turn instructions not functioning -Magellan Roadmate 2000
I am having this same problem. My Magellan was frozen on an old route. I had to completely reset it. This deleted all of my old saved information. Since I did this, it has been mapping correctly, but there is no audio. The volume is turned all the way up. Can you help me fix this problem?
Dec 27, 2007 | Magellan GPS
GPS Logo
199 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
