Question about SanDisk Sansa Clip MP3 Player
Mp3 sansa clip i try to charge and refused to not turn on
I try to charge it and when i want to turn it on its all black
    Problem Solver:
  • 5 Answers
Maybe it's Damaged and you should ask someone to fix it for you
Posted on Feb 24, 2009
SANSA CLIP MP3 FROZE WHILE CHARGING
try removing the battery and putting it back in and see what happends. i not sure this will work
Jun 03, 2012 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
Apr 18, 2009 | SanDisk Sansa Clip MP3 Player
Help with Sansa clip?
Make sure the hold/lock switch is not engaged first.
If it is not, you can suspect either hardware failure or a bad USB cable. Either way, call Sandisk and determine if you are still in-warranty. They can order replacement USB cables if they are still available.
-Tha Mp3 Doctor
Mar 02, 2009 | SanDisk Sansa Clip MP3 Player
Can't get sansa clip to turn on or charge
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
i have found that using my playstation 2 unit or direct tv box (only if you HD) will charge it try that good luck
Jan 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
Won't turn on
What you need to do is first make sure that you are safely disconnecting your sansa clip and not just taking it off the computer. Second you may have a virus in your sansa clip I would prefer you call Technical Support for Sansa clips, the number is 1-866-726-3475, they are open 4am-10pm PST
or 7am-1am EST. Hope this helps
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
