Question about Electrical Supplies
Relay needed I have an 500 watt halogen light that I woul like to hook up to recidential (1/2 HP) garage door opener light socket. However, I am concerned since the light at the garage door opener is only a 60 watts. I think that a relay is needed between the garage opener and the Halogen light. Can someone please tell me the type of relay I need.
    President:
  • 2,692 Answers
Using OHMs law,your 60 watt bulp is presently drawing 1/2 amps and most light sockets are rated between 10 and 15 amps,so in theory, unless stated otherwise(usually because of excess heat) It would be able to carry the 3.34 amps of the 5000 watt bulb.  No relay wodl be needed. If you were to use a relay, and hook it to the existing light socket it would just be a 110v to 110 vold relay to run to a larger current (Amps) rated bulb socket. If you do that I would look for and obtain a 20 amp rated socket. An alternitive to the above is just to wire another light socket to a motion sensor switch ,which would turn on when movment was within the garage and turn off based up on your time setting.Both cheaper and less complicated that a relay.
Posted on Feb 23, 2009
Both the 60 watt globes are good, tested in another device.How do I make my 2 globes work again.
The first thing to do is test the socket the bulb plugs into, may be defective. Use a cheap digital multimeter. About $6.00 from Harbor freight tools
Jun 07, 2016 | Genie Pro Screw Drive Garage Door Opener...
When I open my garage door no lights come on. I changed out both lights with new bulbs, still no lights when I open or by manually clicking the Lights on the wall opener
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
Feb 21, 2015 | liftmaster Garage Door 1/2 Hp
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have the raynor 1245RGD 1/3 HP. Garage Door Opener. The light in the garage used to turn on when I opened the door to the garage. Now it doesn't. I also don't know how to change the time on the clock.
Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Jan 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener works fine. But the lights are not working. Changed light bulbs,Light bulbs are good, I have checked. tried bending the copper tabs in bulb socket out a bit. Still not working. ...
Make sure you are using standard 60 watt bulbs. Some newer type bulbs are causing a problem. If you have a multimeter and are handy it should be no problem to check for 110 volts at the socket and trace the wiring back to the circuit board. There may be burnt or missing traces on the board itself. The click you hear is the relay that controls the lights so you know that is working but there is always the possibility the points are bad.
Jan 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my Craftsman 1/2 HP garage door opener 139-53910. My light bulb does not come on when the garage door is opened or closed as it should. I don't have a manual. Is there a...
Make sure the bulb is good. Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My light won't go off on my craftsman 1/2 hp garage door opener.
This is usually caused by electrical storms. The light is controlled by a relay on the logic board and the contacts must get welded.
Sep 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have two Sears 1/2 hp garage door openers. Cold weather problem
Very strange they both have the same exact problem. I would suspect something with the brackets is changing. When you are having this problem and the light on the receiver unit is not lit, tweak them a bit and see if it comes on. The odds of the logic board in both openers having the same thermal problem is just too high.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electrical Supplies Logo
87 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
