Question about Hotpoint WMA31 Front Load Washer
My washing machine has just stoped spinning or drum will not turn at all but no noise to indicate the bearing had gone it still fills with water model of machine is hotpoint wma 31 can i sort the fault on my own
    President:
  • 1,294 Answers
Problem stated is not clear. You can clarify. Could be the drain pump operation and sometimes from the flow meter itself. The first thing to check is to drop the bottom panel and make sure the drain filter is clean. It sits right in front and just unscrews. Make sure to have enough towels on hand to soak up the water that is left in the tub. After you have checked this make sure both water valves are turned on, clear the error by pressing pause/cancel twice. Check to make sure the drain hose is not kinked and that there is no siphon problem.(Check your pump too now that you've opened up) If the error still returns after checking the above, the next thing to suspect is the flow meter itself. This sits right in line with the water inlet valves. It's just a reed valve that measures the amount of water entering the washer and monitors the pressure switch. You can access it by removing the top and it will be on the left side in line with the inlet valve. Look for holes in this tube, change if any.
Posted on Apr 01, 2009
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Making noise when running
Instructions: 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. 2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) 3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. 4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. 5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. 6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Feb 09, 2011 | Washing Machines
UBNORMAL SOUND DURING DRY SPIN
Washing machine is noisyIt's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently.
Here's a general guide though -
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. If you have a specific noise you are concerned about, either call an engineer
Apr 11, 2010 | Samsung Washing Machines
It has been making banging noises and the drum is sqeaking.the wash programme stops mid cycle we have drained it and cleaned the filter, it is a bit better but is still not working properley.
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | AEG Washing Machines
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Noisy bearing
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Hotpoint WMA31 Front Load Washer Logo
    146 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
