Question about Systemax Venture PC Desktop
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
  • VonZeppelen
    VonZeppelen May 11, 2010
    Could be the power supply but hard to tell at this point. Are you getting any messages on the screen before it shuts down?
  • Dick
    Dick May 11, 2010
    There is no way to tell from the information you have provided. Start with basic troubleshooting and post all the results you get.
  • Systemax Master
  • 4,806 Answers
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Oct 01, 2014 | Systemax Computers & Internet
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Apr 06, 2012 | Systemax Venture S519J (988868) PC Desktop
Need to turn on front headphone jack to a systemax vx2 computer
There are some connections inside your PC, but the people that sold you your PC probably haven't connected them. I suggest you go to a PC expert and ask him to do it... It won't really cost much...
Oct 12, 2010 | Systemax Venture PC Desktop
Montior turns off when hooked up to tower.
Remove the video card and try to put it back in. Make sure that it is fully seated. If that doesnt work, then try replace your video card
Feb 18, 2009 | Systemax Venture PC Desktop
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Nov 23, 2008 | Systemax Venture S519J (988868) PC Desktop
Computer booting problem
FIRST OF ALL TIGHTEN THE WIRINGS
this is what happened to me 2 times
first change ur hard disk drive (HDD) with any other of your may be friend if the problem fixes then it is okay if not t hen may be ur mother board or processor is bad
NOTE:BEFORE U DO ANY THING CONSULT ANY EXPERT PHYSICALLY OR UR PARENTS IF UR A CHILD
Dec 01, 2007 | Systemax Venture S519J (988868) PC Desktop
Systemax Venture PC Desktop Logo
315 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
