Question about Crosman (4032)
Crosman 140 Piston rod replacement parts needed.
I need a replacement for the rubber cup on end of the pump rod for a Crosman 140. Any suggestions where I can find a new one, or a sevicable used one? Any of the other Crosman guns use the same part?
  • Anonymous Mar 25, 2014
    a parts diagram needed
I just rebuilt my 140 that I had as a child, Rick had all of the o-rings and pump cup to rebuild it back to new working condition.
Rick Willnecker
Precision Pellet
37 Stoney Lane
New Park, PA 17352
717-382-1481
717-382-4065 Fax
e-mail airgunshop@aol.com
web site www.airgunshop.net
Posted on Mar 02, 2009
Contact the following person.
http://www.abairgun.com/
Alan Schweitzer
AB Airgun
Box 798
201 North Knox Street
Johnson, Kansas 67855
The process to replace the cup requires an arbor press. See Alan's web site. His rates are VERY low to have him do the work. I've not used Alan yet, but I am preparing to send him my Crosman 140 (c. 1962) for a rebuild. It was my Dad's rifle, now mine. It no longer holds pressure for more than a few seconds.
Richard - in Virginia
Posted on Jun 05, 2009
The rubber cup can be replaced using a rubber from an old tire of a tractor. shape it using a grinder. that's what we do here in our place.
Posted on May 01, 2009
Need a cup seal. where can I get the parts in Canada?
Need a cup seal. where can I get the parts in Canada? - Fixya
www.fixya.com/support/t26025692-need_cup_seal_get_parts_in_canada
20 mins ago - I have some parts numbers for seals etc. Is this a hard thing ... Wherecan I get a manual in English for unidentified spotting scope? I cannot find ...
need new dc 12v cord Spotting Scopes Questions ... - Fixya
www.fixya.com > Forum > Tags > need new dc 12v cord
Spotting Scopes need new dc 12v cord questions and answers. ... ...need repairs i'll also try to help get you in touch with parts or some ideas for service if it's needed. where can i buy a new powerlet seal? i'm looking to put one ... ...new one in canada. ......need a replacement for the rubber cup on end of the pump rod for a ...
Vortex Optics - Site Map
Dec 28, 2015 | Optics
How to install replacement packings
I guess you have found out how to do this by now, but if not its quite easy. These instructions apply to all the Graco St series II sprayers, so the repair kit (Graco # 244-194) contains all the parts to service these different sprayers and you may not need them all for your pump. The back of the kit shows the order in which the parts are installed. Follow it carefully.
The first thing to do is open the repair kit and squirt engine oil into the blisters that contain the packings so that the leather packings soak it up while you are working. Note that the kit will not use all the parts, as it is good for several different pumps, so you need to keep a careful watch on which parts you need.
You need to repack the pump with it held in a bench vice, so first remove it from the sprayer: Disconnect the pump output hose and the suction assembly, then push out the pin that holds the piston into the gearbox piston, slacken the locking ring and unscrew the pump.
Grip the inlet valve body (the lower tapered part) in the vice on the 2 flats. Unscrew the main body and set it aside, take the inlet valve housing out of the vice and remove the valve parts, noting the order of them; you will be reusing the valve seat and cage.
Put the main body upright in the vice and remove all the parts: Unscrew the brass packing nut and tap the piston out with a suitable tool, taking care to catch it. Remove the top packings and the O-ring on the end that goes into the inlet valve housing, clean the pump body including the outlet connection, and inspect the inside of the cylinder to check that it is not scored; if it is, you will have to replace it otherwise the scores will tear up the new packings.
I always keep the old packings in a stack to check the order and number of them when I install the new ones later.
Now remove the packings from the piston, keeping the parts together to check the right order when you install the new ones. There's a drawing on the back of the kit but having the real ones on the bench is a helpful check.
Clean the piston rod and check that the end that goes through the top packing is not scored and replace it if necessary. Rebuild the packings onto the rod being careful to use the correct spacer that goes on first; the thick one is for the rod that does not have a wiper at the other end. Do this with the flats in the end of the rod gripped in the vice. The packings must be installed so that the outer lips face up towards the end of the rod with the hole for the piston pin. The packings are three plastic and two leather between them supported at both ends by spacers. Before screwing in the outlet valve housing (the stud) that keeps the packings in place, check that the valve seat is OK, then install the wiper ring if there is one on the stud with the lips facing the opposite way from the other packings. Install the outlet ball and apply some Locktite on the screw threads and screw in the stud until it is firmly tight (Graco says 3 ft-lbs if you have a torque wrench).
Install the packings into the pump body, taking care again to get them in the right order with the lips facing down into the pump (this will be against the fluid pressure). Install a new O-ring on the brass nut and screw it in until it just contacts the packings but does not compress them. Turn the body upside down in the vice. grease the top couple of inches of the piston and push it through the packings. You will have to tap the rod through. Now tighten the brass nut; it is tricky to get the torque right so if you have a torque wrench tighten to 5 ft-lbs or an extra 1/2 turn from hand tight. Don't overtighten as this will accelerate wear and under tight leads to leaks. Install a new Teflon O-ring on the body end that screws into the inlet valve housing.
Now service the inlet valve and its housing. Remove the Teflon O-ring that sits under the inlet valve seat and the thick washer inside where the suction assembly goes. Clean all the parts thoroughly including the valve seat and cage. Examine the valve seat land where the ball will sit to ensure that it is not pitted; if it is you can turn it over to the other side if that is OK, otherwise you will need a new inlet valve seat. Install a new O-ring that goes in the groove under the valve seat.
With the inlet valve housing gripped on the 2 flats, in the vice, install the inlet valve parts; first the valve seat, then the new inlet ball and finally the valve cage with the legs downwards around the ball. Grease the threads on the end of the pump body and the O-ring on the end of it. Screw the body into the inlet valve housing and tighten it firmly but not too much (the seal does not depend on it being tight)
Now install the pump section into the gearbox housing. When it is in far enough, the top of the pump body will be about flush with the inside of the hole that it comes through. Now install the piston pin; this is tricky as you need to line up the hole in the crank piston, with the hole in the rod, so you may have to first screw in the body too far and rotate the rod inside it before you can push in the pin which requires that you also lift the retaining spring. Once the pin is in place, rotate the pump body until the top is just flush with the inside of the bottom of the gearbox housing, then tighten the locking ring. Reinstall the outlet hose and inlet suction assembly.
Jul 15, 2014 | GRACO INC 390 Stand Airless Paint Sprayer
My gun has no power and seems the piston seems to chug when I pull the trigger
Have you oiled the gun? Take some light oil, gun oil or 3in1 oil and oil all moving parts, including the piston rod . Oil the barrel a well.
Jun 08, 2014 | Crosman Nitro Venom Air Rifle .177 Cal....
Why would the bottom blow out of a six month old slave cylinder from a Toyota land cruiser
The only end that can blow on a slave cylinder is the push rod end and a sudden loss of fluid means that the rubber cup in side has failed or the push rod has been pushed out of the cylinder . Replace it with a new one
Sep 20, 2013 | Toyota Cars & Trucks
I own a 40 year old crosman 140, .177 cal air rifle that will not pump up air pressure. I can pump the forearm as much as I want and it never builds up air pressure. Can you help? Thanks LeRoy
REMOVE THE FOREARM PUMP ASSY SEE IF THE CUP IS WORN OR SHRUNK
PUT SOME LIGHT OIL ON THE CUP AND SPREAD
IT OPEN AND FLEX IT SOME SO THAT IT SPREADS OUT TIGHTER IN THE TUBE
YOU CAN ORDER PARTS FROM CROSSMAN
Jan 29, 2010 | Optics
Crosman 140 pump rod adjustment
Contact Alan at ABairgun.
I own a Crosman 140 (c. 1962). The nut should be tight.
May 12, 2009 | Crosman (4032)
Repairing Crosman 140 .22 cal. pellet gun
Check out www.abairgun.com for parts
Apr 27, 2009 | Sport & Outdoor - Others
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman Powermaster 760 pump bb gun won't hold an air charge
Take a look on amazon Amazon com Crosman Powermaster 760 pump and take a look for replacement. have a nice day
Feb 12, 2009 | Crosman (4032)
Crosman (4032) Logo
4,321 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
Martin Clarke
Martin Clarke
Are you a Crosman Optic Expert? Answer questions, earn points and help others
