Question about Sony MHC-RXD5 Shelf System
Protect power keeps coming on - rdx5 MHC
I try play a dvd, any increase in volume, protect power message comes on - where do I start to look. I have spent the afternoon checking wires and come up with no solution, please and thanks
  • 1 more comment
  • Tanis Feb 23, 2009
    help please if you can
    thanking you very much
  • Tanis Feb 24, 2009
    thanks, I am going to start this project right now, thanks again and I will reply here soon. (finally got my password figured out, zeros or lettters - hehe, so confusing
    teajay1
  • Tanis Feb 25, 2009
    Hello all, thankyou all so much!! I really appreciate the "helping hand" your team has given me, I had no idea where to begin looking for the problem. I checked and cleaned all the wires (took the sticky duct tape off), checked connections, changed plugins. I found the white and orange plugs were in the wrong places on the back of the tv due to some moving of furniture around so I could get my floors redone.
    Once I could hear sound out of the 'extra" set of speakers I knew I was on the right track.
    Again, thankyou very much and I am saving this site for future, hope you stay on the airwaves :)
    Thanks
    teajay1 (Tanis)
    Scholar:
  • 85 Answers
Protect usually means a speaker wire problem. remove all connections and redo them making nice tight twists in the connections the spliced end should be no more than 1/4 inch long. make sure to do this for all speakers as well as on the back of the unit.
Posted on Feb 23, 2009
  • 2 more comments
  • Chuck Feb 23, 2009
    it could be one little strand of copper so just dont do a quick look see. Just remove all the wires on speakers as well as on the back of the unit. Then post comment to see if that helped or not. then i can help you further.
    another diagnosis is to make sure if unit is not defective by removing all speaker wires from back of unit. yes i did say all speaker wires. Now try to turn volume up and see if it is internal problem. If you get a protect this way this means the unit is in need of service or replacing
    did you try my last diagnosis by removing all wires from back of unit? and then see if it still happens? if i helped fix it how bout a fix ya....thanks and good luck any other questions try charles_farrah@comcast.net it is easier
  • Chuck Feb 24, 2009
    so what is the verdict? if it works ok when all speaker wires disconnected and doesnt go to protect (turning volume up) you can then attach one speaker at a time and see which one gives you the protect mode. there could be a malfunction in one speaker. or like i said earlier that if it still goes to protect with all wires off then it is internal and something more major is wrong.
SOURCE:
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
Protect push power
yea i have the same problem. i dont know but i think maybe the amp brd is faulty.
joe.
Apr 22, 2008 | Sony MHC-GS100 CD Shelf System
Problem with turning my system on....
whan a unit goes into protect, it could be a bad speaker, shorted speaker wires. or the most common fault is a blown audio o/p ic in the unit. due to being compact units they are more difficult to work on than the full size unit. the part typically runs between $25.00 to $75.00 usd. if you are good with working on small places and are good with soldering give it a try. the ic will be on a heatsink. good luck.
Jan 31, 2007 | Sony MHC-ZX10 CD Shelf System
215 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
