Question about Califone International 1030AV Turntable
Califone 1450K I recently moved and my Califone (old, but in good shape and has always worked) 1450K now will not turn on. It may have been stored on it's side by the movers. What can I do to fix it? Do you have any idea what is wrong? I tried plugging it into a surge protector also and still no luck. It's frustrating!
  • 515 Answers
Ya, this is a tough one. If it was on it's side, and not handle properly, something may have come loose and caused some damage inside. If you have absolutely no power, then more than likely the power transformer fried. Not much else in these things that could have caused such an issue. At this point, you have to decide whether it's worth getting repaired, or buying a working used one. They go on ebay for about $30-50, which is much cheaper than getting it repaired. Transformers for these units run around $20-30, then you have to tack on labor, which will be in the 40 min range - that's if its the transformer. But I do understand if it has some personal value, so that is something to consider. Hope this helps some. - Justin DJPROAUDIO
Posted on Sep 02, 2007
SOURCE:
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Platter not spinning
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Mar 22, 2014 | Califone International Audio Players &...
Califone 1875 turntable
Ask them what the part is they can't get and report it back here. Fixya experts like myself sometimes can track them down.
Feb 26, 2014 | Califone International Audio Players &...
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
Califone 1420 k "Wobbling sound"
If you take the platter off you may find a rubber "idler wheel" that rides on the inside rim of the platter. It may be worn or glazed over and hardened. Might try cleaning with denatured alcohol. If that doesnt work you may need a new idler wheel. West Tech Services is a place that comes to mind that may carry what you need.
Mar 05, 2009 | Califone International 1030AV Turntable
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Califone 1450k
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!1
Nov 08, 2008 | Califone International 1030AV Turntable
Califone dvd/vcr 200
Hi, you can download the manual from the site given below:
www.retrevo.com/s/Califone-DVDVCR200-DVD-Players-review-manual/id/540dj397/t/1-2/
Hope my info solves your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Califone International DVDVCR200 DVD...
Califone International 1030AV Turntable Logo
538 people viewed this question
Top Califone International Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Tom Chichester
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
