Question about Toshiba Satellite M65-S821 Notebook
QWER keys do not work, but the rest of the
QWER keys do not work on Dell laptop Inspiron 1150, but the rest of the keyboard works. How can I fix?
    Problem Solver:
  • 17 Answers
First thing to try is re-securing the keyboard ribbon on the motherboard. to do that on most dells its as simple as popping off the top strip where the power button is and then remove the screw holding the keyboard down and carefully pull the keyboard away till you are able to pull the retaining clip up and remove the ribbon from the motherboard. then reinsert it securely and push the retaining clip down. sometimes there are screws on the underside of the laptop that hold the keyboard on but ive never come across a dell that does that personally.
If re-securing the ribbon doesnt do the trick, then you are better off buying a keyboard off of ebay(usually between 15 and 20 dollars) than messing with the insides of the keyboard. good luck.
Posted on Feb 23, 2009
    Novelist:
  • 180 Answers
Sounds like a little something was spilled on that area of the keyboard. Luckily, the keys are easy to pop off. Use a tiny flathead screwdriver to pry under one edge and take them off. Then use a Q-tip with some rubbing alcohol on it to clean around the area and replace the keys. Don't forget to clean the keys themselves just to be sure. If you want to go all out, you can remove the entire keyboard, run it under some water, let it dry then replace it. Direction for keyboard removal can be found on the Dell site. I had to do that for my wife's laptop after our granddaughter spilled something. Let me know if you need any additional info.
  • Toshiba Master
  • 4,806 Answers
Hi there.
Many laptop keyboards tend to start doing this after prolonged use (including my own), there is no way of fixing them.
What you need to do is replace the keyboard, in the meantime, you can use a small usb keyboard or use the on-screen until you get the keyboard replaced.
Good luck and thanks for using Fixya!!
How do i install a new keyboard into a dell inspiron 1150
here ya go
http://support.dell.com/support/edocs/systems/ins1150/sm/keyboard.htm#1084976
Keyboard can be found on EBAY
Sep 27, 2010 | Dell Inspiron 1150 Notebook
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
Some of the keys on keyboard stopped working
Yes replace the keyboard. It is usually not a hard job so have a look here < LINK
Best of it.
Thanks for choosing Fix Ya
May 29, 2010 | Dell Inspiron 5150 Notebook
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 network cable unpluged.
simple there might be settings problem . go to the network places icon in start bar and do a right click then choose Diagnose and repair..then it will works but if it says that there is a device problem then might be your router is not working correctly
Mar 17, 2010 | Dell Inspiron 1150 Notebook
Keys qweruiop not working on startup (first 15 minutes or so) on physical keyboard on HP G60-533CL Notebook PC running Windows 7 Home Premium (64-bit). Keyboard Driver Standard 101/102-Key or Microsoft...
Take the computer to a qualified technician, who can replace the keyboard, as the least-expensive "try" at trouble-shooting.
Since a keyboard transmits "codes" to the motherboard,
e.g., left-shift-has-been-pressed, and left-shift-has-been-released,
and the motherboard interprets those codes, it is NOT likely that
the motherboard is misinterpreting the codes, especially given that
the "bad' letters are in a straight line on your keyboard.
Find an external USB keyboard, and plug it in.
If it works correctly in the first 15 minutes, then the problem is NOT the motherboard.
Jan 04, 2010 | HP Computers & Internet
Qwer and uiop keys not working on a dell inspiron laptop. i don't have access to the laptop. i purchased it for my daughter who is away at college. Any suggestions/solutions? Thanks.
Keyboard is more than likely bad. Call dell or your local PC shop to get it replaced. If it is still under warranty Dell will send you a keyboard to replace it with. If you take it to a local PC shop tell them if it is under warranty
Sep 12, 2009 | Computers & Internet
The whole keyboard
just wait as it may dry out .
if not a keyboard can be order on ebay for around 30.00
Feb 25, 2008 | Dell Inspiron E1505 Notebook
Toshiba Satellite M65-S821 Notebook Logo
1,709 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
