Question about Dishwashers
Maytag MDB4800AWW Not Working Properly
Hello there,
I am looking to get some help with my dishwasher mentioned above. It does not seem to be cleaning the dishes. It will go through the cycle, but when it is done, I open it up, and the 3-in-1 tab is sitting there. It has been released from the hatch, but not disintegrated. I don't know where to start looking.
Please if anyone can help it would be greatly appreciated!
Thanks
5 Suggested Answers
SOURCE: Maytag MDBH950AWB
You need to remove the lower spray arm (the little plastic nut in the middle of the arm can be removed with a 3/8" nut driver), then the dome housing, then the impeller, then the entire cover. This gets you down to the motor where the chopper blade is at. There's probably something hard that's getting in the blade. If you don't find anything, you'll need to replace the motor and the seal kit, which includes the blade and the seal that does not come with the motor.
Posted on Feb 14, 2009
jonniewalker
  • 1031 Answers
SOURCE: Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Posted on Mar 29, 2009
    mmoorree
    SOURCE: KitchenAid Dishwasher Door Pops open during cycle
    The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
    With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
    Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
    Posted on May 07, 2009
    heatman101
    • 43501 Answers
    SOURCE: Maytag Diswasher DOP Model MDB6600AWW Serial 15365054LE Water
    Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
    Dishwasher Problems - Waterwill not drain out
    heatman101
    Posted on Aug 25, 2011
    Dishes not coming out clean
    Hello
    There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
    Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
    Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
    Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
    Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
    Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
    Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
    Sep 13, 2011 | Maytag Dishwashers
    How do I clean lower spray arm of Maytag Dishwasher model DWU8260?
    They are virtually impossible to clean so that they work properly again....
    I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
    Dishwasher SprayArms not Spinning
    How to Buy ApplianceParts Online
    A bad heating element causes many problems in dishwashers...
    Dishwasher Problems The HeatingElement not Working
    DishwasherMaintenance DishwasherResidue and Film on Dishes
    heatman101
    Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
    Apr 13, 2011 | Maytag Dishwashers
    I have maytag dishwasher leaves food residue
    there is a filter on the inside bottom of the dishwasher check and clean it
    May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
    Maytag eq plus, not cleaning properly, seems the
    I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
    Dishwasher Spray Arms not Spinning
    How to Buy Appliance Parts Online
    Dishwasher Problems The Heating Element not Working
    Dishwasher Maintenance
    heatman101
    h
    Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
    Dishwasher does not drain properly
    most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. In your case it may not have been drilled out at all as plumbers sometimes forget to do this especially as you mentioned the unit was brand new.! Also check the non return valve under the filter and make sure the drain pump can turn freely.
    Hope this helps.
    Jan 24, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
    Our Maytag quiet series 200 does not clean or rinse dishes properly. It leaves film all over cups and dishes. Water also seems not to be draining out. It is 6 years old
    It is not the dishwasher. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
    Sep 07, 2009 | Maytag Dishwashers
    Maytag quietseries 300 dishwasher not cleaning properly
    UNGLOGGED THE BOTTOM/TOP . CLEAN IT AND SHOULD BE OKAYARMS SPRAYER, THEN IF IS GOOD AN NOT ENOUGH WATER CHECK WATER VALE SCREEN
    Aug 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Maytag will not start, has power and control panel running fine
    Do you ever clean it with a dishwasher cleaning agent and run it on any wash mode?
    Mar 08, 2017 | Maytag MDB9600A Jetclean II Built-in...
    My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
    Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
    Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
    Dishwasher not cleaning well
    How hot is the water ;120 is the minimum it should read at.If its below 120 than look for either a bad heater element or turn up the water heater.Rinse Aid needs to be added if its out.
    Apr 11, 2008 | Maytag Performa PAV2200
    Dishwashers Logo
    66 people viewed this question
    Top Dishwashers Experts
