Question about Nextar M3 Car GPS Receiver
I t is very hard to get my nextar gps charged ..I have to play with the terminals for a long time ..checked the charger works fine ..once gps take the charge works properly
    Brigadier General:
  • 3,614 Answers
better to change or replace now the charger.
Posted on Feb 23, 2009
Even when my gps is turned off it loses battery power. How can I get it to stay charged?
You could hard wire the car power adapter for your gps to a Constant 12 volt wire and ground to prevent your gps from losing it's charge. Else you will need to plug in the car charger for your gps and charge the battery a bit before you can use it.
Oct 01, 2011 | Nextar X3 GPS Receiver
My nextar 14-bct was not on for a long time then I charged battery a short time then when I was playing with it in house it went blank and now will not turn on
I have a nextar 14-bc and I was having similar problem and I found that the power in jack had a broken solder joint and when I thought it was charging it was not. I would not turn on until I discovered the broken solder joint inside on the power jack. I resoldered it and after it charged up it was up and working again. You might check on that.
Aug 19, 2011 | Nextar I4-BC GPS Receiver
Hi, my gps nextar x3i-02 is not turning on, what can I do?
The problem with your nextar is either the battery or the charger is faulty. Either ways you need to test them both then replace the faulty part. That is why the gps receiver is not powering up.
Do not panic when your gps seems to be acting funny, There is no problem without a solution, and if it is beyond repair the solution will simply be that you replace the gps receiver.
Solution:
  1. Test the battery in another gps receiver, to see if it will power it on,
  2. Charge the battery in another gps receiver for about 2 hours with another charger then try to power it on,
  3. If it turns on, then it means the battery is okay and working fine, but if it does not turn on the other gps, then it means the battery is bad and need to be replaced.
Solution:
  1. Test the charger on another gps receiver to see if it will work.
  2. If it does not work then you need to replace it,
  3. But if it works then you do not need to replace it.
After carrying out the test, you will be able to detect the problem and solve it.
Hope this information helped.
Dec 23, 2010 | Nextar X3-02 GPS Receiver
Battery doesnt stay charged like it used to ? approx three years old , works ok with charger plugged in
The battery has come to the end of its service life, you will need to replace the battery. Contact Nextar at www.nextar.com for information.
Jun 17, 2010 | Nextar I4-BC GPS Receiver
Broke my nextar gps car charger. Do you sell them
No. FixYa supplies advice only and mostly without charge.
FixYa does not sell any tangible goods of any description.
I'd usually suggest a supplier for your Nextar charger but you have not said which country you're in.
Nov 15, 2009 | Nextar X3-08 Car GPS Receiver
Why does my gps nextar show a red light and not turn on screen is black tryed pushing reset button but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 25, 2009 | Nextar P3 GPS Navigation System
After charging my nextar q4-04 the unit will not come back on. i have tried the reset and nothing happens
Are you using the manufacturer adaptor/charger. ? If not the polarity needs to be checked. Your proable solution replace the batteries. If that doesn't work then you have to open up the unit, and close to the battery compartment check the diode.
Aug 19, 2009 | Nextar Q4-04 Car GPS Receiver
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Nextar M3 Car GPS Receiver Logo
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
