Question about Singer Electronic Steam Press Iron
Singer sp 16 ironing press. How do I disassemble lifting arm? It was pulled too far up and the spring has come out? otherwise perfect working
2 Suggested Answers
SOURCE: my singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Posted on Nov 05, 2009
heatman101
  • 43501 Answers
SOURCE: singer iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Aug 22, 2010
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Oct 02, 2016 | Singer 9960 - 9960 Quantum Stylist
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
Jan 22, 2014 | Singer Electronic Steam Press Iron
Worn out pad
I order my replacement press cover pads online at "Sew4Less" - silicone covered pad - they sell for $12.95 /ea plus $5.00 shipping (measures 24"X9") and fits my Steam Press SP660 perfectly.
Apr 19, 2009 | Steam Fast SP-660 Iron with Auto Shut-off
Singer steam press csp-1 iron
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
My Braun Si 3120 Optistyle Iron is leaking water from steam holes
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Jan 10, 2009 | Irons
Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Oct 22, 2008 | Irons
Breville ir23 steam iron
My electronic steam press has been performing perfectly until yesterday. I can not longer get it to turn on? Any suggestions? carolb745
Jun 17, 2008 | Singer Electronic Steam Press Iron
Singer Steam Press PRO9S
I have a Singer steam press Pro-9S, the top plate is loose from the screws holding the hot plate and the cover arm, I like to know how to remove the hot plate cover from the arm to tighten those screws. Thank you.
Feb 18, 2008 | Irons
Singer Electronic Steam Press Iron Logo
244 people viewed this question
Top Singer Irons Experts
Sean  Piquet
Sean Piquet
Are you a Singer Iron Expert? Answer questions, earn points and help others
