Question about Estate TGDX640JQ Gas Dryer
Dry comes on normally and progressivley gets cooler. Turn it off and after it sits for a while and I can start it again and it does the same thing over again.
After taking apart the whole dryer and checking the burner assembly i found no burned out or fouled out parts. I put the dryer back together and left the back panel off pluged it back up and started it up the burner came on for no more than 1 minute then went off. At that time I removed both thermostats from the burner housing but still attached to the wires and started it again it stayed on. So the answer is u need to change the thermostats. To check and make sure just pull off the back of the dryer an remove the thermostats from the burner housing then start this sill be tour answer and the piece is about 25.00 good luck an God bless.
Posted on Jul 13, 2009
After washing grass clippings from my toro zero turn mower, the engine turns but won't start.
Probably sucked a bit of water into the intake... I would pull the sparkplug, make sure it is dry, remove the air filter for the same reason, then reinstall the plug, spray a generous helping of starter fluid in the unit and turn it over. It should start. Also, if you have additional electronic components, make sure they are completely dry , and try starting it again. When in doubt, if it still will not start, let it sit for a few days... As with troubleshooting any system, look for the last thing that has changed... In this case, it sounds like you got it wet... Let it dry out, and try again. I am confident that the result will be a running unit.
Jun 19, 2015 | Toro Garden
When starting vehicle,the cooler fan comes on and the vehicle wont start.When this happens the engine check light does not come on.
Good morning I don't know what you are working on but possibly your ignition switch, that would explain why when you turn it off and then turn it back on it works. I don't know if this helps you or not. I know when your switch is going out you will get power to some things power not to others. I hope this helps you good luck
Mar 17, 2015 | 2006 Nissan Navara 2.5
On a warm day if the aircon is not on the engine temp will sit over harf way is this normal
Best thing to make sure of is it's stays fairly close to 1/2 way. over 1/2 way isn't bad unless it starts to get into the red zone, if that happens shut off the vehicle and tow to a shop. Now one way to keep your engine cooler is to go find a cooler thermostat and have it installed. It will open sooner.
Feb 19, 2011 | Jeep Cherokee Cars & Trucks
How do I get the Malber all in one washer dryer to dry hotter. It seems to be getting cooler and cooler. It didn't use to be a problelm. I nolonger have the manual.
There is a wire which connects to a connection towards the front of the drum itself on the right side which when the drum wobbles, comes off. When it gets loose, it may start to arc so that the spade connector needs replacing. In extremis the whole unit may need replacing. This seems to govern whether the heater elements turn on or not. If you put the connector back on, I'll bet the heater starts to work again
Feb 03, 2011 | Malber WD1000 Front Load Washer/Dryer
I have a ge profile bottom freezer fridge model PDS22MCR. It's making a loud humming noise & the fridge & freezer are getting progressivley warmer. fridge is up to 45 & frezzer 11 in a matter...
The compressor is not starting every time and later it will start again...replace start relay and capacitor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 17, 2010 | GE Refrigerators
I have both Heater and Evaporative cooler fitted to my house early this year. When I turn on the cooler with the Comfort control remote, air coming from heater outlets but not from the cooler outlets. Have...
mate .. stop playing with it if you dont know what your doin honestly... sounds like you could end up costing yourself more money. it will b under warrenty call back the installer
Nov 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Coolant and engine temp both running much hotter than normal. almost overheating but not quite. hotter they get the less cold my A/C becomes
Mine was doin the same thing when i got it. We fixed the " fan clutch " which apparently sits in front of the radiator and helps cool the AC(according to mechanic). When this got fixed the AC ran cooler and car started running cooler. Like yours, mine was overheating, but running hotter than it should.
Jul 26, 2009 | 1998 Audi A4
HP pavilion ze2000 laptop doesnt turn on
Hi there.
Take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> e1bc638.jpeg.
Good luck and thanks for using FixYa!!
May 19, 2009 | HP Pavilion ze2000 Notebook
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Sep 12, 2008 | Garden
Estate TGDX640JQ Gas Dryer Logo
66 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
